2003 TL-S type
Old Jun 13, 2012 | 09:50 AM
TechDriver's Avatar
2003 TL-S type
Hi does anyone have a wiring diagram for the windshield wiper switch. The windshield wipers will not turn off and I need the prints to troubleshoot. Thanks
Old Jun 13, 2012 | 09:51 PM
01tl4tl's Avatar
wanna bet its the switch on the steering wheel ?
Old Jun 18, 2012 | 10:16 PM
TechDriver's Avatar
I believe it is the switch but I would sure like to verify it before I spend the money on one.
Old Jun 18, 2012 | 10:36 PM
yungone501's Avatar
J-series addict
If you believe it's the switch, simply disconnecting it will tell you.
Does it run only with key on or does it continue to run with key off?
Assuming that it only runs with key on, you could (as mentioned) have a faulty wiper switch, bad Drivers Multiplex Control Module (DMCM), bad (stuck closed) intermittent wiper relay and even a damaged wiring harness. I see the DMCMs go bad a lot on these. This a computer that's very similar to a Body Control Module (BCM). Although when these go bad, they typically cause multiple symptoms.
james357
Feb 13, 2016 02:37 PM
Brandle34
Sep 23, 2015 07:20 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
VladkaR
Sep 2, 2015 11:36 PM
