2003 TL-S ATC6 Swap Frankenstein Edition (BAYA gave up)
I refuse to put a 4th automatic transmission in this car. Manual swap it is. The ATC6 has been secured along with the shifter cables, shifter box, shift cable bracket (just snapped the one on my 01 Accord last night -_- all ready got a used one installed !!!), clutch, flywheel, donor wiring harness, starter, full clutch hydraulic assembly, clutch pedal, and brake pedal. ALL FOR 600! I am starting to dissect the electrical diagram and I plan on following John's atc6 swap https://www.v6performance.net/thread...6-swap.253328/. My only questions as of right now are what axels to use, shall I obtain a cherry picker and do a full-on pull or suffer, and can I get away with using a Dakota Digital SGI-100BT. I don't plan on using almost anything from a CL except the mounts. This may not be pretty but at the end I need no CELs. Frankenstein part 2 here we come!!! Pt 1 was the AV6 swap that absolutely crapped out on me after 60k miles. I need to get AAA and go on one last recorded ride with the auto.
Just to clarify, the ATC6 is a V6 Honda accord manual transmission?![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
TIA
TIA
andrew070489
1G TL Performance Parts & Modifications
54
12-27-2011 11:14 AM
