2003 TL ATF Fluid Change
I do most all maintenance to my cars but never tried to do this before. Just want to make sure I am not getting in over my head. Sounds like it is easy as:
1. unbolt drain plug and drain
2. install new crush washer
3. find fill hole (which I havent been able to do) and add 3 qts on honda ATF
https://acurazine.com/forums/showthread.php?t=138831
Originally Posted by tweedle99
If you don't have an oil jet kit installed yet, I would try to get the fill bolt off first since the dealer torque it down pretty tight.
Originally Posted by acurabum
I use a small funnel to fit the dipstick hole and fill 3 qts in around 10 min. only.
Get a small funnel...........
Michael wan das known people who have broken multiple rachets trying to remove the fill/drain bolts.Especially i got the oil jet so don't take a chance ........................
If you have teh oil jet its a simple (10 or 12mm) Bolt. remove that pull straight up, nothing to hurt or screw up. You cant damage it or install it wrong. nothing to worry about
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
