2003 3.2 TL - Cruise Control
I don't remember where the troubleshooting guide is but the first place I would check is the brake sensor, its the most common reason it stops working. Also, this may be obvious but make sure the actual cruise button on the left side of steering wheel is pressed.
PATRICKPBME (03-29-2018)
Check the throttle body pulley where the cruise control cable connects. It's plastic and commonly breaks. You'll have to pull the top plastic engine cover to see it.
Tabasco
2G CL Problems & Fixes
03-14-2008 09:56 AM
