2002 Tls Fogs
2002 Tls Fogs
I got a 2002TLS but I want to change the fogs to the xenon bulbs to. Does anyone know where I could get some from? Also what type of bulbs I need, cause the acura dealer that I bought my car from is a dumbass and they keep telling me a different type of bulb, so I just wanted to double check with some of you guys. Do any of you know how to get your fogs to come on with your parking lights, not only with your headlights? Lastly, how do I get to the fogs, do I just basically need to get under the car, I got the factory ground effects and my ass is to big/lazy to jack up the car and check
check FAQ
For fogs to come on with parking lights -- check the FAQ on the side -- line by line directions on how to do it.
To get the fogs, you'll need a socket wrench with a somewhat long extension to get at the bolt that's holding it in place (under the front lip spoiler). Once it's out, you may need to get a flathead screwdriver to gently pry out the fog light housing (use a towel to minimize any paint damage) Once it's out, you can change the bulb.
Want to change it to xenons? Use the search function (on the side again) and look it up. You may need to do some serious electrical changes to fit xenons properly (without frying the wiring).
I'm sure someone has responded faster than me but hope this helps.
- derrick
- derrick
xsilverhawkx
09-28-2015 06:51 PM
