2002 TL Audio Question
I am looking to hardwire my Sirius radio in my 02 TL.
Can someone suggest a location as to where I can tap into for power? Driver's side fuse panel? If so, can you give me some tips on "How To"? I am pretty handy so I'm sure I can do it.
Any ideas would be greatly appreciated!
ALSO - Can someone recommend a good and reputable car audio installation shop?
Thank you!
Thank you!
You will probably get answers posting here, but you're posting in the 3rd gen TL forum, and your car is not a 3rd gen TL. You might want to post in the 2nd gen forum.
If you take off the panel under the steering wheel and look at the back side of the fuse panel, there are 5 spots for a female spade electrical conector. 2 are switched, 2 are constant and 1 is switched with the headlights. I dont remember which ones are which but they are there
You can try to connect at Ign harness ..remember..some XM and sirius work on 6 or 5 volt..not on 12 Volt ..not like starmate work on 12V.. just make sure before you cut Cigrate lighter plug and hardwire it.. You can check on unit it self..it will say input Volt or on Lighter plug will show out put Volt
12 VOLT CONSTANT WHITE (+) IGNITION SWITCH HARNESS
ACCESSORY WHITE/BLACK (+) IGNITION SWITCH HARNESS
2006 Acura TL with nav
Originally Posted by silver01TL
I just installed the Starmate replay in the sunglass holder above. I ran the power through a cigarette adapter to the outlet in the center consol.
navtool.com
ILX Audio, Bluetooth, Electronics & Navigation
32
12-22-2015 12:46 PM
navtool.com
14
10-31-2015 08:16 PM
navtool.com
09-25-2015 06:21 PM
