2001 tl Oil on the ignition coils
i was changing the spark plugs, and noticed that there was a hint of oil on one of the ignition coil on the back middle cylinder. But on the back right cylinder the ignition coil had a lot of oil, even on little bit on the spark plug.
i suspect that the seal is leaking.
actually recently changed those, but may be not set properly. is there a correct procedure to set those seals?
what happens if the seals are not replaced?
does that oil harm anything?
is there a special way to insert it. i did it the best way could. any tips?
i never paid too much attention there.
i did not read anywhere people say anything specific about these seals, and if something can go wrong. so i just installed it the best i could and did not bother. until i opened the coils to replace the spark plugs.
You can install the plug well seals backwards, and you can tear them as well. Did you look in the plug well when you did the gaskets? The oil could have been there before. Clean it out with brake cleaner and compressed air, or a rag soaked with brake cleaner twisted around a screwdriver. Check it again in a few days, if no leak, check it again in a month or so.
the oil was not there before, as the first time when i removed the coils, there was no oil on either of the coils. but this time there was.
JIGS (06-17-2015)
seafoam does not cause leaks, its basically 3 types of oils that clean and lubricate
Please everyone follow the ratios as I have given many times- came direct from Seafoam head tech guy:
Gas tank 2 oz per gal of fuel, use 1 can to just under half tank 2 times (no need for vac method then, but still need to clean TB air plate)
Oil 1.5 oz per QT of oil and 15 minutes to 100 miles drive before change with fluid warm
Mater Vac port/TB inlet 1/2 can, Deep Creep- seafoam aerosol recommended over liquid.
Can be tricky to do right thru vac port= fuel tank gives a much more effective treatment for your dollars!
the oil is around 5 qt, and i used 10oz. changed oil after 30miles.
10 oz for the vac port/TB (when you say aerosol you mean the seafoam spray)
2. need to inspect that
3. new spark plugs.
I suspect he's using a different term for the same part you just installed. ie, plug well seal = plug tube seal = coil tube seal = coil tube grommet. Typically, in this instance, the rubber seals under the valve cover bolts are called grommets.
IBankMouse
06-13-2020 12:53 PM
Pham Alvan
03-16-2016 09:17 AM
