2000 TL--What's causing this noise?
I've had my 2000 TL for about 9 months. Now 130,000 miles. I drive it a lot. Got it at about 116,000 miles. At 125,000, I noticed a gradual increase in road noise/mechanical noise. Kind of a thrumming sound.
It is speed related, but not RPM related.
If it were my old Subaru, I would suspect that half-shafts need to be replaced.
Any guesses on the cause of the noise?
Tranny would be a suspect, I suppose. I did a 3X3 fluid change at 125,000. AKAIK, its the original tranny with the ?jet? factory mod.
Could it just be tires? They're getting a little worn. Just rotated fronts to backs. Improved steering feel. The ones now on the back are more worn that the (now) fronts.
Do half-shafts need replacing, like my old Subaru?
Wheel bearings? Other thoughts?
if its speed related odds are its a bearing. Can you pinpoint the side or end of the car that the noise is coming from?
2003 TL-S w/Navi NBP
I would suspect bearings, too, except that you say you 'just' rotated the tires. Did you 'just' start noticing the noise? Bearing noise would be a little louder during high speed turns (putting weight on one side) and high speed dips in the road. Try swirving back-and-forth at high speed and see if you notice the noise being a little louder.
I did not just notice it, its been getting progressively worse over the last 5k miles.
This is all subjective but...
It sounds like its coming from the front. When I swerve, the noise gets slightly louder. When I brake, it gets louder.
Another sign it may be wheel bearings--when I brake at speed, I get just a hint of judder that disappears if I brake harder. Under harder braking, its smooth and good. Under light braking, a bit of judder that stabilizes in a second or two.
Still sound like wheel bearings? Is that a DIY job for someone with hand tools? I have replaced pads, and torn down 2 engines, but never replaced wheel bearings.
What you can do to save money is remove the spindle/hubs yourself, buy the bearings yourself, and just take them to a shop and let them pack and press the bearings. You will have to remove the spindle/axle nut, which requires a special socket that you can get as a loaner from most parts store.
dont replace anything yet
get to a place with a lift, or your jackstands, and use a mechanic stethascope - 3-5 dollars at harbor freight or parts stores
spin each wheel and listen for noise in the bearings
the right rear wheel bearing is a very common failure on the TL
makes a `whirring` bearing wearout type noise that travels thru the car and you cant pinpoint it,,, is speed related, and easy DIY
iirc the thread title was `RR wheel bearing DIY because someday it will happen to you!`
the right rear wheel bearing is a very common failure on the TL, makes a `whirring` bearing wearout type noise that travels thru the car and you cant pinpoint it,,, is speed related, and easy DIY
Front wheels, however, were different. Spinning is harder, of course, since I'm moving the half shafts and CV joints. When reversing the spin, there's about 1/8 play, and a noticeable noise at the junction of the half shaft and the tranny.
Does that mean its half shafts? CV joints?
Thoughts?
jack the side up where you suspect the noise is coming from. grab the tire at 12 oclock, and 6...shake the snot out of it. i had a wheel bearing go which made no sound at all, when i would turn i could feel severe looseness coming from one side, shook it, figured it wasn't any balljoints, replaced bearing and it was solid afterwards.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
