2000 Acura tl lowering spring problem
Old 03-06-2014, 01:18 AM
3rd Gear
Timurn14's Avatar
So I just install my truhart lowering springs in the front and the front right side of the car sits a little lower than the front left side. So I was just wondering if there is any reason why it's like that. Any reply would Help thanks!
Old 03-06-2014, 02:04 AM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
You should let the springs settle in.. they will be over stiff at first and can be a little un-even, give it a week until you start to worry..
Timurn14 (03-06-2014)
Old 03-06-2014, 02:24 AM
3rd Gear
Timurn14's Avatar
Alright thanks dude!
Old 03-06-2014, 03:27 AM
HairyMonkey019's Avatar
which is right, which is left?
Passenger side or driver?
Old 03-06-2014, 08:13 AM
M224armstrong's Avatar
My eibach pro kits have been on for about two weeks now and my left rear sits lower than my right rear! Same thing but in the back! Does anyone know possible problems that can cause this? Eibach prokits with koni yellows
Old 03-06-2014, 08:17 AM
06 NBP 6MT TL
cincinattlguy19's Avatar
It may not be a problem at all, it may be the spring/strut still settling in! It could be many things though
Received 16,260 Likes on 11,971 Posts
a lot of things.
1)are you sure you're on level ground? do not measure on a driveway, as it will be off.
2) did you install it correctly?
3)one side is heavier than the other, there's the battery, the transmission and a lot of other stuff hanging to one side.(hint the drivers side)
laid67 (03-06-2014)
Old 03-06-2014, 03:07 PM
3rd Gear
Timurn14's Avatar
Oh ok could it maybe that I didnt tighten my upper camber arm bolts the same?
Old 03-06-2014, 03:35 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Is the shock fully seated in the fork? I would double check that.
Chevelle66 (03-06-2014)
Old 03-06-2014, 09:07 PM
laid67's Avatar
Also I had issues with binding one time with my front upper strut mounts where the strut wasn't resting where it was supposed to, this will be pretty obvious upon installation though.
Old 03-06-2014, 10:28 PM
Mr.Helpful Diagram
ErickUa5's Avatar
+1 on the fork, if not installed correctly it can pop out and then your in trouble.
Seen it on a thread here on the TSX side.
02-25-2020 09:57 AM
Zonian22
11-14-2015 01:20 PM
Mike Bertram
09-10-2015 09:27 AM
DUECE_DXJ
09-07-2015 06:40 AM
Zonian22
09-02-2015 08:19 AM
Quick Reply: 2000 Acura tl lowering spring problem
