2000-2001 TL ecu part#
I tried searching and didn't find any info. I need to get a ecu for a 2000-2001 TL, auto trans and FED. Does anyone by any chance know the part# and are both years interchangeable? I also need to get a engine harness for the ecu, are those interchangeable for both years as well? Any if would be much appropriated, so thanks in advance ; )
2000 TL Black on Beige
This is a start . . .
37820-P8E-A53 CONTROL MODULE, ENGINE 2000 TL 1153.62 865.22
37820-P8E-A54 CONTROL MODULE, ENGINE 2000 TL 1124.05 843.04
37820-P8E-L53 CONTROL MODULE, ENGINE 2000 TL 1153.52 865.14
37820-P8E-L54 CONTROL MODULE, ENGINE 2000 TL 1111.10 833.33
Also quick question, i also need a wiring harness for the ecu. When looking at car-part.com do i need a DASH harness or ENGINE harness? Want to be sure i have the correct parts before ordering, thanks in advance!
what do you need the ECU and harness for?
Yep, the parts numbers are to get the parts numbers.
Dealer cost gives you an idea what they cost new; try to pay 10¢ on the dollar for used.
Your VIN may determine exactly which ECU you use, or there were several that worked for that model.
The dealer parts department might be the best option for info.
Putting a honda oddy tranny since mine is shot. I have a 99 TL and was told since its a 4sp and the oddy is a 5sp i need those 2 parts to make it work. Im so sick and tired of these trannys. My cars been down for months and trying to get the parts to get it back on the road.
![](http://img.auctiva.com/imgdata/1/2/6/2/2/5/7/webimg/364942546_o.jpg)
![](http://img.auctiva.com/imgdata/1/2/6/2/2/5/7/webimg/364942465_o.jpg)
that looks like the ECU to motor harness.
Thanks fsttyms1!!! Where is the ecu located in the car, trying to get the part number to see if it matches? This whole tranny failure is becoming nothing but a big headache!!
Kind of like under the radio / center console. Remove the side panels. 2 bolts hold it in (one on each side).
cycdaniel
12-17-2019 10:58 AM
2000, 20002001tl, 2001, 37820p8ea54, 37820p8el54, a53, acura, ecm, ecu, fed, location, p8e, program, rl, tl
