2 questions...springs n resonator
Old 09-30-2004 | 12:48 AM
z3Ro's Avatar
Mr. 2tone
i have 2 questions...some u know im getting H&R Sports springs...the guy at the car shop says that i need to get a camber kit...so my question is how many people on here have the sports springs WITHOUT a camber kit n have no problems?...my 2nd question is that i read somewhere on here that theres a resonator with the stock mufflers...is it possible to take them out?...thx...
Old 09-30-2004 | 01:12 AM
subinf's Avatar
One on the right for me
yes you can take the resonator out, just cut it out and weld in a pipe, although you might get a slight change in tone. i would rec. that you just get a magnaflow 4 inch round resonator and replace your stock one with that.
Old 09-30-2004 | 01:16 AM
subtledreamer's Avatar
woooo!!
regarding the camber kit: No, you dont HAVE to get a camber kit. but it is definately recommended if you are going to drop more than 1.5-1.75" Many people on this forum who are lowered that much or less don't have camber kits (they are still running on stock shocks, too).
Old 09-30-2004 | 01:24 AM
Edr0e's Avatar
If you want your tires to last longer than 5k miles i suggest you get a camber kit and a good ole alignment. Thats if you dont want to replace your tires so often.
Old 09-30-2004 | 01:30 AM
BeemerKiller's Avatar
NO you dont have to have a chamber kit. I was having the same question when i dropped my car. But my machanic told me that dropping the car makes the handling a little bit better, on the oppostie, chamber kit will kill the handling a little bit. So if you drop your car and get chamber kit = get nothing on handling.
How much is the maganflow resonator? I would like to get one. Weill that help on gaining any HP?
Old 09-30-2004 | 01:32 AM
z3Ro's Avatar
Mr. 2tone
thx kuz i dont wana spend more $ if its not really necessary...n about the resonator...y does the xhaust have a resonator?
Old 09-30-2004 | 01:42 AM
BiggyMcWang's Avatar
USDM UA5 A-Spec
IMO no need for camber kit. All I did was go to tire guy I trust. He said alignment was all I needed plus because of the sport drop, there was no problem with getting it aligned back to stock. Reason I bought H&R Sport is because I never would have to buy a camber kit.
Old 09-30-2004 | 01:43 AM
ou sig's Avatar
Boomer SOONER
I have the Comptech springs without a camber kit....all good for a while now. I went to get an alignment after I got the springs and they said it was very near stock.
Old 09-30-2004 | 02:06 AM
NYZGREATST's Avatar
Sig Rho's Finest
i just put my h &r sports in. VERY SEXY!!!!!!!!!!! there is def neg camber in the rear meaning the tires look like ? / \ but from what i hear its supposed to make handling better
Old 09-30-2004 | 02:08 AM
z3Ro's Avatar
Mr. 2tone
thats awesome...no need for camber kit...so how does changing it misalign my car?
Old 09-30-2004 | 02:14 AM
subinf's Avatar
the main purpose of a resonator is just to provide a smoother exhaust tone, and often used in combination when putting on an aftermarket muffler to eliminate the raspy sound that accompanies many of the mufflers. i like the 4" round magnaflow magnapacks because they are very small yet will not restrict the exhaust as much as the stock resonator. i doubt there will be substantial power gains from just replacing one resonator with another, but i guess every little bit helps. replacing with the magnaflow will probably change the tone a tiny bit. and they are quite inexpensive, my shop sells them for 80 bucks and im sure you can find them lower since cost on the resonator is around 32 bucks.
Old 09-30-2004 | 09:58 AM
USDM UA5 A-Spec
It always starts with negative camber, but you have to drive around to cause more as the springs settle in... After about 2 weeks to 1 month, then get it alligned. Getting it aligned now will only make you go back again after the springs finally settle. Yeah after that allignment, you won't need a camber kit.
ExcelerateRep
12-11-2015 12:58 PM
eastsideride
10-15-2015 04:26 AM
merc009
09-29-2015 03:06 PM
Kitsune13
09-24-2015 02:25 PM
Rcelestino93
09-23-2015 10:01 PM
Quick Reply: 2 questions...springs n resonator
