120+ mph in 3rd using SS???
O.G.
I usually race other cars just using D4. But I decided to try out the SS mode last night. I had a clear straightaway for like a mile or so. I put it in SS and took off. I got up to the rev limiter and past it a little for like a good 5-10 secs when the fuel cut off. Before it cut off, I got up to 120+ (~122 mph) in 3rd. I thought that was pretty good for 3rd gear. What do you guys think?
FYI, there were only a few cars around so I did not endangered anybody.
BlackShadow....there for a while I was only using drive mode when traveling past 100mph. But I had also noticed that once I reached 100mph, the acceleration wasn't all that great. Others turned me onto using SS mode and I sure do like it. Previously I was only using SS mode to zip in and out of traffic.
Your top speed in a particular gear can be calculated fairly easily. Basically, if you calculate the circumference (outside diameter) of the tire and then calculate tire RPM (as a function of engine RPM, Gear Ratio and Final Drive Ratio) you can multiply the two and solve for MPH. There are 4 things you need to know:
Maximum RPM, gear ratio, final drive ratio and tire size. Obviously everyone with aftermarket wheels will have to plug their tire size information into the following equation. For the purposes of this discussion, let's use 7000RPM (the published fuel cutoff of a TL-S), 3rd gear and the stock tires/wheels on a TL-S. To find wheel speed in RPM, we do RPM/Gear Ratio/Final Drive Ratio
7000/1.021/4.428
We get 1548.334 wheel RPM. Let's go ahead and turn this into RPH (revolutions per hour) by multiplying by 60 since we ultimately want to solve for speed in miles per hour, not miles per minute. We get 92900.05 RPH, so we'll use 92900. Now we need to find out the circumference of the tire so we can see how far the car travels in one revolution of the tire.
A tire's size is expressed in the following format: 215/50/17. 215 is the tire's width in mm, 50 is the aspect ratio (the ratio of the tire's height to the tire's width) and 17 is the wheel diameter. First, let's convert mm to inches for simplicity's sake by multiplying the mm measurement by 0.039. The tire's width is 8.385 inches. Now, to calculate the tire's height (distance from the inner part of the tire that touches the wheel to the outer portion of the tire that touches the road) by taking the aspect ratio (in this case 50, as in 50%) and multiplying that by the tire's width.
8.385 inches * .50 = 4.1925 inches
Now we can calculate the diameter of the wheel/tire combo. Take 4.1925 inches, add the diameter of the wheel (17 inches) and add another 4.1925 inches for the "top" of the tire and we get
4.1925 + 17 + 4.1925 = 25.385 inches.
As we all remember from school, circumference = pi*diameter, so we have
3.14159 * 25.385 inches = 79.74926 inches. Let's round that to 79.75.
Almost done, I promise. Now let's convert that figure to miles. There are 63,360 inches in a mile, so we take inches/63360 to get the circumference in terms of miles (again, since we're looking for miles per hour)
79.75/63360 = 0.001259 (rounded, of course)
Now that we have wheel speed in terms of RPH and tire circumference in terms of miles, we simply multiply the two numbers
92900 RPH * 0.001259 Miles = 116.9611 MPH. Yay! Now you know that a TL-S with stock wheels/tires at 7000 RPM in 3rd gear is going 116.9611 MPH. You can use this newfound knowledge to impress the ladies.
As a disclaimer, I'll say that this formula is pretty accurate although it doesn't take into account the deformation that occurs on tires at high speeds that can ultimately affect the circumference -- it's assumes that the circumference is constant. Also, the more rounding you do with your figures, the further away from dead accurate you will be.
Sorry for the long post... I'm sitting at work nursing the printer (read: refilling the paper tray every half hour) waiting for an 11,000 page print job to complete and I figured writing this up would be more fun than just staring at the wall.
7000/1.021/4.428
Originally posted by TypeSDragon
Binh, I just don't believe you that you drove your car that fast. How come you never speed when you are driving with us.
O.G.
RAdams, thanks for the detailed explanation.
Super Troll
Originally posted by BlackShadow
Are you talking about the guys in the city?
Radams....that calculator is too complicated. I have a much simplier calculator on how to determine top speed in each gear.
1) insert key into ignition
2) start car
3) put gear shift in SS mode
4) push gas
5) read rpm gage when fuel cut off engages
6) change gears and repeat steps 1-5
2) start car
4) push gas
It only seems complicated because I inserted a lot of commentary and explanation between each step. It's actually pretty simple. I tried to make it as easy as possible because some people are still under the idea that using SS or manually shifting will allow you to go much faster in any given gear when that is not true. My point was that every gear has a pretty finite speed that it will allow the car to go before you have to shift.
O.G.
Originally posted by ALFAV6
I hope your not talking about us .... since you went to 120 i assume you raised your car back up... if not i would love to see how low your car got when you hit 120:p
BTW, I haven't raised up my car yet.
Re: 120+ mph in 3rd using SS???
BTW: What can you get in 5th
( j/k )
O.G.
Re: Re: 120+ mph in 3rd using SS???
( j/k )
( j/k )
Super Troll
you guys always obey the speed limit.
O.G.
i am glad you notice...we don't speed.. everyone just drive slow thats why it seem like we're speeding
O.G.
Originally posted by FKNA
The TL's automatically shift from first to second in SS mode, right?
Originally posted by initialD
Is your TL 99?Why I asking you that because I just tried it lastnight it cut before 180kmh about 110mph in 3rd gear with my 00TL.Maybe because 4sp has taller gear ratio,that why they can reach 120mph in 3rd??Tell me what you think.
O.G.
Yes my TL is a 99 and that's probably why I can hold 3rd gear a little longer than the 00+ TLs due to the fact that I only have 4 gears. I also held 3rd gear up to 7000 rpms for a good 5-10 secs before the fuel cut off.
joflewbyu2
08-18-2019 10:38 PM
navtool.com
31
11-16-2015 08:30 PM
