100k Engine Maintenance Parts
Hey guys, I am doing my 160,000km (100k) service soon, here is the parts list I acquired:
19200-P8A-A02 --- WATER PUMP (YAMADA)
14400-P8A-A02 --- BELT, TIMING (197YU26 GB-323)
19301-P8E-A10 --- THERMOSTAT ASSY. (NIPPON THERMOSTAT)
19501-P8C-A00 --- RADIATOR HOSE, WATER (UPPER)
9502-P8E-A00 --- RADIATOR HOSE, WATER (LOWER)
14510-PGE-A01 --- ADJUSTER, TIMING BELT
38920-P8C-A02 --- BELT, COMPRESSOR
56992-P8A-A01 --- BELT, POWER STEERING PUMP (MITSUBOSHI)
CAM SEALS / OEM PART # 91213-P8A-A01 X 2
FRONT CRANK (MAIN) SEAL OEM PART # 91212-P8A-A01
VALVE COVER GASKET / OEM PART # 12341-P8A-A00 X 2
SPARK PLUG TUBE SEALS / OEM PART # 12342-P2F-A01 X 6
Is there anything else I happened to have missed? Or is a good idea to change/do at 100k miles?
Thanks!
Thanks!
Unless you plan on dropping the tranny or yours is leaking there is no need to replace the front main seal. Also unless you plan on adjusting the valves you dont need the valve cover gaskets. You wont need the cam seals.
For NGK part numbers, the part # is ZFR5FIX-11 (TL-S application) or BKR6EIX-11 (NSX application/colder plug). I think the 4th digit is the heat range.
IK16 and IK20 are Denso part numbers. Stock is the IK16, and the IK20 is the colder plug.
Thanks!
Thanks!
Do the Camshaft and CrankShaft sealings are needed? i tought you only need to Replace them when they leaked. Also the Thermostat and Radiator Hoses being needed??? those stuff is (BWB) buyable when broken arent they? those stuff usually dont brake or needed to be changed until Broke or Leak i think?
My List is as:
Timing Belt x1
Timing Idler x1
Timing Adjuster x1
Timing Hyd Tensioner x1
Water Pump x1
Acc Belt x1
P.S. Belt x1
Oxygen Sensors:
Upstream x1
Downstream x1
I think those cover All of 120K+ Maintenance for 5 years or 105000 Miles
Then Change all of the Seals i Guess at 200K Mark
Also the Thermostat and Radiator Hoses being needed??? those stuff is (BWB) buyable when broken arent they? those stuff usually dont brake or need to be changed until Dry up and Leak i think. Besides if you change the Anti-freeze when needed that helps out the cooling system so Thermostat and Hoses are OK i suppose?
My List is as:
Timing Belt x1
Timing Idler x1
Timing Adjuster x1
Water Pump x1
Acc Belt x1
P.S. Belt x1
Oxygen Sensors:
Upstream x1
Downstream x1
Last edited by Skirmich; 10-27-2009 at 11:40 PM. Reason: Sorry for DOUBLE POSTING!!!!!!!!!!!!!!!
sockr1
10-01-2015 01:31 AM
03, 100k, 14400p8aa02, 19301p8ea10, 2002, 2004, 38920p8ca02, 56992p8aa01, acura, maintenance, mdx, mile, service, tl, wwwacuraclcom
