100,000 miles now what???
Ok, I know there is information on this site about what I'm asking, just at work right now and didn't really have time to search, so before so one tears into me just wanted to give that disclaimer. If someone would be kind enough to give me a link that will take me where I need to go I would appreciate it. Thanks.
AZ Community Team
Received 7,770 Likes
Moved.
You should get more action in the main forum.
As far as I know the biggie is 105k - Water pump, timing belt, etc.
with spark plugs and if applicable (some 99s irc) cap and rotor-wires
Also should do valve adjust with the 105 service
seafoam it!
seafoam it!
109k Service was done @ 110k
3rd tranny and ecu was installed, every fluid was flushed and refilled @ 126k
NGK Iridium spark plug was replaced @ 130k
Transmission fluid, break discs and pads and tires were replaced @ 135k
Right now It's almost getting 140K with no problems at all. and Engine oil and trans fluid will be flushed and changed soon @ 140k
My MPG is 28 right now. (City and Hwy combined)
運転することを愛
Don't overlook ALL fluids. You may have already done them recently, but I did my belt/water pump just before 90K and did power steering fluid, brake fluid, coolant, tranny oil and crankcase oil all then (oil change is obviously more routine) on top of the other items listed above.
Hey, I understand. You can't do more than you're financially able to do. Try to get it done as soon as possible though, even if you don't get it serviced at a Honda/Acura dealer. There are some very good mechanics out there, you just have to find them. By the way, if anyone needs service in Northern NJ and you need a knowledgable, reliable, and AFFORDABLE mechanic, I got the hook-up!
Neglecting preventative maintenance on any car nearing 10 years old with 100k on the odo is playing "russian roulette". Why gamble your ride by neglecting recommended service ? Our TL's are solid upper end Honda engineered vehicles which will perform well for 200k if properly maintained. So, do your car and yourself a big favor and do the stuff.....unless you don't care and want another car. DO IT NOW !!!!!!!!!!!! or pay later.
100k--
Timing Belt
Water Pump
Hydraulic Tensioner
Spark Plugs
Drive Belts
Valve Adjustment
New Honda Type II Coolant
And based on recent experience with old cars, I would also replace the thermostat, upper radiator hose and lower radiator hose while the cooling system is drained.
Also check if the other items are up-to-date:
- Brake Fluid Flush (commonly overlooked)
- Cabin Air Filter (commonly overlooked0
- Transmission Fluid (if not done within the last 60k)
Timing Belt
Water Pump
Hydraulic Tensioner
Spark Plugs
Drive Belts
Valve Adjustment
