03 tls 6 speed dyno with 99 ecu
Old 08-17-2009 | 06:14 PM
phee's Avatar
I got the Shifts
as you can see i either need to get the type-s ECU or get a tune because my car gets extremely rich (almost 9 afr) around 3.5-5k rpm. im leaning torward a tune with AEM fic so that i can use the FIC for my turbo kit down the road.
infos
Run 2 was with the IMRC stuck closed
run 3 was with the IMRC stuck open again
Run 4 was with the IMRC working
pulled 243.5 HP and 204 FT-lbs of tq with the tl-p ecu. at 88% humidity and 89 degrees outside.
not bad considering i only have intake, and headers.
tuner said i should see 260-270 with a pulley, exhaust (i still have a tl-p exhaust) and a tune with AFC neo or AEM FIC
Old 08-17-2009 | 06:18 PM
jjashaa's Avatar
Avant Garde Wheels
you need.
to buy an exhaust. =]
or make one. =]
but sick #s man.
more than what that guy with the S/C put down.
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/help-dynod-240whp-w-s-c-hbp-tuned-739987/
Old 08-17-2009 | 06:21 PM
phee's Avatar
I got the Shifts
Originally Posted by jjashaa
you need.
or make one. =]
but sick #s man.
https://acurazine.com/forums/showthread.php?t=739987
Old 08-17-2009 | 07:01 PM
AznWay's Avatar
Ok now it's time to go for 300HP an let Alben pay you another $50 on your new bet
Old 08-17-2009 | 07:20 PM
phee's Avatar
I got the Shifts
i know right he shouldve never bet me
300 seems attainable with my future plans
Old 08-17-2009 | 08:40 PM
e r y k's Avatar
damn. nice
I WANT.
fix yo air fuel foo.
Old 08-17-2009 | 08:43 PM
godizus's Avatar
Needs wheels
good numbers dude!
Old 08-17-2009 | 10:49 PM
fsttyms1's Avatar
Need to get the type-s ECU and see what it does. It should help.
Old 08-17-2009 | 11:07 PM
LacViet's Avatar
291hp & 245 tq @ 3.5psi
Those are nice numbers. With all the bolt on mod, you should reach 260-270 easily. With the S/C, over 300whp is piece of cake. I hope I can reach 300whp next week when I bring the car to tune the S/C with around 5psi.
Old 08-17-2009 | 11:45 PM
phee's Avatar
I got the Shifts
ill be ing for you lacviet! post your dyno
phee's Avatar
I got the Shifts
couldnt i use a piggybac instead?
Old 08-18-2009 | 04:54 AM
Rajca's Avatar
wham bam thank you ma'am
those are some sick numbers. what kind of dyno was it?
Old 08-18-2009 | 07:34 AM
phee's Avatar
I got the Shifts
DynojetJ
Old 08-18-2009 | 08:05 AM
fsttyms1's Avatar
not unless you find a way to raise redline with one.
Old 08-18-2009 | 10:17 AM
prlwhtl25's Avatar
I GOT BOOST...DO YOU?
3" exhaust would do nice with your setup...plus you plan on going turbo...
Old 08-18-2009 | 10:32 AM
baby z's Avatar
Phee, those are some sick numbers. For those of us not familiar with your car, what have you done to get your car there?
Old 08-18-2009 | 11:40 AM
phee's Avatar
I got the Shifts
03 cls engine
05 tl 6 speed tranny
intake
headers
1999 ecu
Old 08-18-2009 | 11:43 AM
phee's Avatar
I got the Shifts
What numbers do you put down with your charger and 6 speed?
Old 08-18-2009 | 12:54 PM
prlwhtl25's Avatar
Didnt dyno yet.. waitin on the module from rich . for the swap. then i could get a tune..with emanage blue. and see some number.
Old 08-18-2009 | 02:07 PM
JCharged's Avatar
not bad at all phee. The AFR's I don't like too much...When I'm @ WOT I'm riching out to 12's-11's
Also running TL-P ECU, I still need to dyno.
Exhaust work, pulley, and possible spacers should do the trick.
Old 08-18-2009 | 03:19 PM
6MTUA5's Avatar
No He Can't
So do you have Richie's harness or is that limp mode?
Old 08-18-2009 | 03:24 PM
phee's Avatar
I got the Shifts
richies harness. The rpm is listed on the graph.
Maybe I should take the money from my piggyback fund and just do a 3.5. The extra zdisplacement should lean me out right?
Old 08-18-2009 | 05:38 PM
Rajca's Avatar
ur still gonna need a tune bc u might be running too lean. either way, if ur going boost ur gonna need a management unit one way or the other. might as well get it now and unleash all the power.
Old 08-18-2009 | 05:46 PM
phee's Avatar
I got the Shifts
^6oh i know. i was just kidding. im going with the neo to hold me over
Old 08-18-2009 | 06:02 PM
Rajca's Avatar
if i would have seen the thread earlier i would have sold it to u
Old 08-18-2009 | 06:34 PM
crazyasiantl's Avatar
nice numbers. makes me wanna keep my car now
Old 08-18-2009 | 06:42 PM
gold2003tl (90)'s Avatar
2003 TL-p
03 cls engine
intake
headers
1999 ecu
nice numbers phee, i see you were able to bolt an 05TL tranny to a j32a2. im wondering if its possible to bolt up a 3rd gen automatic tranny to a j32a1. or if its possible to just do a complete 3rd gen engine and automatic tranny swap. i assume its possible to do a complete 3rd gen engine and manual tranny swap, but i am just wondering about the automatic. thanks
Old 08-18-2009 | 07:18 PM
Rajca's Avatar
u cant do the engine swap. diff motor mounts and mounting points.
Old 08-18-2009 | 07:26 PM
2003 TL-p
ok, but what about a 3rd gen 5speed automatic tranny swap, will it bolt up to a j32a1 or j32a2? could you use the 3rd gen ecu or use a 2nd gen tl-s ecu on it? i am not worried about the shifter because i could prob rig something up for the automatic.
Old 08-18-2009 | 07:37 PM
6MTUA5's Avatar
No He Can't
You would have to change a lot of things using the 3rd Gen ECU
Old 08-18-2009 | 08:45 PM
phee's Avatar
I got the Shifts
A 3g auto will bolt up but your car will run in limp mode
Old 08-18-2009 | 09:13 PM
2003 TL-p
hmm, well there must be a way to get it to run normally...or not. is it in limp mode because of the ecu not being the 3rd gens or is in limp mode cus our ecu is freaken out?
im just trying to explore my options, is there any other automatics that will bolt up? thanks phee
Old 08-18-2009 | 09:21 PM
Silva-type-s's Avatar
Got your mom in
nice!!!! a/f is high but nice..
inspiration for all 2nd genners out there
Old 08-18-2009 | 09:40 PM
SlickShiftNall6's Avatar
Quarantuning
Nice numbers Phee! Your doing good considering I dynoed 243/ 214 with the same mods plus a rt high flow cat, and p2r spacers...
About tuning; I plan on using a emanage blue when I go back in for dyno round 2. Let us know what unit you choose and the results. Good Luck.
Old 08-18-2009 | 10:04 PM
fsttyms1's Avatar
I really need to get mine dynoed.
Old 08-18-2009 | 10:23 PM
phee's Avatar
I got the Shifts
have you ever?
Old 08-25-2009 | 03:38 PM
phee's Avatar
I got the Shifts
do you think the 02 sensor might be the reason im running rich?
Old 08-26-2009 | 04:41 PM
CJITTY's Avatar
Ackniculous One
i got a strong feeling that ya boy Uncle Jitty is gonna be hiring Phee to do my six spped swap very soon..seriously
I got to drive his car the other day, ridiculous
Old 08-26-2009 | 05:14 PM
fsttyms1's Avatar
have you ever?
No, but i can run pretty much door to door with a 04 Mustang Mach 1 with 410 gearing and some misc add on parts making 315 at the wheels to 100mph
Old 08-26-2009 | 05:15 PM
fsttyms1's Avatar
??? i am too and i have the CL-S ECU. (with and without the cat) I need a tune.
Quick Reply: 03 tls 6 speed dyno with 99 ecu
