03 TL wont stay running!!! Please help in at my whits end. I've tried everything.
03 tl wont stay running!! No codes. It will run in limp mode . Changed MAP, IAC, EGR, FUEL PUMP SCREEN, ECM ETC. Wont run unless I make it go into limp mode by tripping code. Then soon as I clear...code it won't run
Ok so you have an engine that was working. Has it been operating at all since you installed it in the "new" TL? Was there a problem with the "new" TL before the replacement engine? Were they the same year?
Does your OBDII reader give you operating information or just error codes?
What happens when you crank the engine? You said it won't stay running, what does it do, how long does it run?
When you pulled the engine I assume you replace the timing belt etc.? Are you sure you had everything lined up correctly?
You replaced parts, but have checked spark, fuel, air? Did the wiring harnesses line up and nothing is missing?
Thefireball (03-27-2023)
6G TLX-S
Did you swap the PCM too ?
Nicky Pass
02-09-2003 02:44 PM
