03 Foglights bulb swap
Has anyone replaced the bulbs yet in the 03 foglights? If so, how difficult was it and what is the best bulb to use for the closest match to the headlights?
I've searched for an answer to this question, but all I come up with is the DIY for the 01 driving lights and the recommended 19224 replacement bulb - does this apply to the 03 foglights as well?
WhizzBomb
Very easy. Takes about 20 minutes. You'll need a 10mm socket and an extender. If you'd dropped, a lift is helpfull but not required. I'm using PIAA Extreme Whites and it's a pretty close match (until I got the 6k HID). I'm an idiot with tools, so it I could do so I'm sure you can too
Good luck,
Joe
Good luck,
Joe
u just need to unscrew the 2 bolts under the front lip, then ur whole housing comes out, and after that it's just simply unplug and plug back in the new bulb. Very easy... as for the color, i don't know cuz i use yellow bulbs. It's about a 30min job. Good Luck
Originally Posted by roger-alan
Whizzbomb - which PIAA bulbs do you use - is there a model number?
TLSAnthracite - which yellow bulbs do you use? Might look into those too...
Thanks guys!
Thanks guys!
I agree with Bxscig.
Only way to get those deep yellow color is to get those yellow film on the housing or get PHILIPS 3000K rebased hid kit for fog. This is what I am planning on doing.
WhizzBomb
Thanks,
Joe
WhizzBomb
Thanks,
Joe
WhizzBomb
Originally Posted by Whizzbomb
Sorry man, I threw out the comtainer they came in. I'll stop by the the place I got them today and see if I can find out.
Thanks,
Joe
Thanks,
Joe
I'm currenly using the PIAA MAX Arctic Xenon Blue 9006 55w. Hope this helps.
Joe
quanaman
01-09-2023 07:33 PM
