03 Acura TL-S | Spark Plugs |
Get yourself some NGK Iridium ones 😉
So check this out:
https://www.rockauto.com/en/catalog/...park+plug,7212
This webpage has excellent pricing and most every part you'd ever need for your TL. I'd suggest bookmarking that to hold onto it - there's also a coupon code floating around for Acurazine members that gets us 5% off.
If you use the link above, it'll put you directly in the spot for your Acura, which is guaranteed to be the right size. And then the spark plug packaging has information on the torque specs, as do approximately 676,000 pages on the internet, according to my google search just now.
It's 13 ft/lbs btw, but that's low enough where your torque wrench likely doesn't really work unless you've got an inch/lb setup. The packing of the plugs will have an alternative method of getting them in there tight enough by counting the turns.
fuzzy02CLS
10-27-2003 06:11 AM
