02' tl-s tranny problems
hello guys! my 02 tls is started to form transmission problems, for example there is hesitation from 2nd to 3rd gear. and also sometimes when i put the car in drive the gear stick clicks idk what that is. anyways what transmission would be compatible with my car?
Ouch so they sell you a car on its last legs??? If you buy it from a Dealer you should make them fix it for you under warranty..
If you buy it from a Private Seller then your best bet is to Save up for an Accord V6 2006-2007 Transmission which is completely compatible with our car and its a lot more reliable than you current transmission..
What ever you do: DONT REBUILD YOUR CURRENT TRANSMISSION.
AcuraGangg (04-17-2014)
Check the 2nd Gen's "DIY" sticky for tranny fluid replacement procedures.
The basic 1x3 Drain and Fill is simply draining the tranny's fluid pan reservoir and replenishing with a bit more than 3 Qts. Honda DW1 fluid. Some other simple things to try include replacing the spin on external ATF filter and cleaning the solenoid screens.
AcuraGangg (04-18-2014)
SidhuSaaB
05-30-2020 12:40 AM
Pham Alvan
03-16-2016 09:17 AM
