02 TL-P to TL-S6
Unregistered Member
02 TL-P to TL-S6
Hey guys, my tranny just took a shit and it's time for the 6 speed.
I was considering my options, and I had a couple questions. I want to get a Type-S engine and a CL-S6 tranny. Unfortunately, I have a 2002 TL-P with the TL-P ECU. Would it be possible to do the following build:
-CL-S6 Tranny
-TL-S Engine
-TL-S ECU
-Type-S Richie Module
I would prefer that setup over doing a complete CL-S6 conversion, as the wiring scares the shit out of me. Plus, I like using my moonroof. Air bags and ABS are a plus too.
If that isn't possible, I would take the next step down and go for:
-CL-S6 Tranny
-TL-P Engine (Keep Existing)
-TL-P ECU (Keep Existing)
-TL-P Richie Module
Please advise, as I want to keep the wiring work to a minimum.
-CL-S6 Tranny
-TL-S Engine
-TL-S ECU
-CL-S6 Tranny
-TL-P Richie Module
Unregistered Member
If the first build is possible, I'm guessing I'll have to get the Type-S engine harness. Is that the only harness I should have to change, if I use the module?
The tl-p engine harness will work you just have to get a window switch for the intake manifold release control. MSD makes I don't remember the part number though
I think with either Swap, Keeping the Wiring to a Minimum would be Impossible...
But I dont know your budget going to the TL-S route will be more expense since you need the Engine + ECU, And Adding up that the 6 Spdo Swap is around 3K you will need around 4.5K to do the whole thing TL-S...
Option 1 is not only possible but more worth it. I went with option 1 and everything but TCS works. I love driving this car and definitely has a lot of throttle response.
The Richie V6 harness is very easy to install, it only took about 2-3 hours so get wired in and I'm new to wiring. Azine has been there for me so you get stuck on the way we'll answer your ?'s.
Unregistered Member
So I'll go for the first build. Seeing that I'm getting a TL-S engine and ECU, I'm assuming I'll need the TL-S engine wire harness? Or can I just use the TL-P engine wire harness?
Yea, I figured that the TL-S engines were so cheap now, it would be stupid not to get it. And yea, I wouldn't even attempt anything if not for AZine members.
I used a type s engine wire harness. I wanted to do a 1 for 1 swap and not mess with it.
I think you need an IMRC module in order to make the butterfly to automatically open, I don't think mine works
i just have my butterfly wide open all the time.
here was a guys selling MSD that you needed to make it work. Also theirs link in his page on how to hookup MSD
https://acurazine.com/forums/car-parts-sale-361/power-adder-your-p-cl-tl-s-intake-manifold-msd-window-switch-imrc-849729/
Unregistered Member
Hmm, if using a TL-S engine, TL-S wire harness, and TL-S, why can't the car control the secondary stage?
What controls that part on the real TL-S? I figured the ECU would do it via a switch in the engine. Can't I just swap that over?
Unregistered Member
I've been looking for the parts to buy, and I have a question. Obviously I will be using an 03 CL-S tranny, but I don't know whether to use an 02 TL-S engine or an 03 TL-S engine.
If I pick an 02 engine, can I use an 03 TL-S ECU? Or should I not mix and match?
I have an 02 TL-P, so I figured I would get an 02 TL-S Engine and 02 TL-S ECU. However, if it is cheaper/easier to find 03 parts, should I use them?
The part numbers are different, so I was wondering what the differences are. Which model year stuff should I get?
SCEPTRE
Jul 2, 2005 10:54 AM
ZeroPSI
Mar 14, 2005 10:42 PM
