'02 3.2 TL-S Service questions - 1st post
9th Gear
Just registered for this site a short while ago, searched on the brake rotor tsb and have (2) other questions regarding supposed 'service issues'.
Dropped off the wife's TL-S for its 30k service this morning (purchased new in 4/02) and a rec'd a call from the friendly service writer indicating the rotors were warped (as suspected) $215 to resurface & pads, along with suggestions that I should consider flushing the tranny fluid ('it's brown) for $160 and clean the throttle body, $90! Both of these suggestions seem premature to me......30k miles & tranny fluid flush, huh? My wife drives the car easy, basically back & forth to work 15 miles each way, mostly highway and we average about 14,000 miles annually.
Wondering what recourse I have with the brake/rotor tsbs, given the car has 30k. I understand the problem could have occcured from over torqueing the lugs, or that the rotors may have failed prematurely as a result of a defect.
Looking forward to any suggestions I might use when getting back to the dealer.
Regards,
G35C033
Regards,
G35C033
Warped rotor's should be resurfaced and pads replaced for free...there are many memebers on this board who can vouch for this. Dont listen to the BS of the dealer!!! I have had mine done twice already at no charge.
I have changed my tranny fluid on my own...1st time at 15k and soon at 30k. Just buy the fluid yourself and stick to Honda fluid.
9th Gear
Thanks for your reply abluetypes78. Not being a do-it-yourself maintenance man, I rely on the dealer, whom i've not had any previous concerns with. So you think 30k on the tranny flush and tb cleaning is legit?.....that's what i'm trying to confirm.
the fluid is most likely brown and needs to be changed but if you have a shop or mechanic you go to besides the dealer then you will get a cheaper price. The dealer is over priced but its something you need done...i am not sure about the throttle body..............maybe someone else can answer that
I'm like you--I don't want to do maintenance. However, a tranny fluid change is around $200 each time. I have a '02 TLS purchased brand new in March '02 (60k miles now), and have had 2 tranny fluid changes at the dealer (the third change came free of charge with my 2nd transmission
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Basically, I don't have a straight answer for you, but I guess just try to choose the lesser of two evils every 15k miles.
9th Gear
Originally Posted by clc
According to my DEALER'S maintenance checklist, I noticed there was a tranny fluid change every 15k miles, although it does not specify it in the owner's manual. I noticed this line item was included after the tranny malfunction thing went "full-blown." I seriously doubt that changing the tranny fluid will keep the tranny from malfunctioning, if the tranny is defective in the first place.
), and I'm about to head in for 60k service this Friday.
Any one on the tb cleaning?
Appreciate the help.
Regards,
G35C033
2003 SSM TLS
There has been some history of TBs getting gummed up on TLs with high milage causing idle fluctuation etc... but with less than 30K, no way. I would wait till 60K or so before I would do the TB cleaning, unless you have some sort of problem. Just MHO of course.
9th Gear
I'll get back with an update re: the rotors.
G35C033
G35C033,
I have an '03 TLS with 18K miles. Just last week the dealer REPLACED my front rotors and pads due to the rotors being warped. You should not pay for this with less than 50K miles on your car. Just my
By the way, I notice you are in Connecticut - which dealer are you using?
9th Gear
Originally Posted by SMF-TLS
G35C033,
Regarding the tranny flush, after looking at the fluid, which was a very light brown and in the service mgr's. opinion not indicative of a burnt unit, I decided to pass. Service mgr. said they generally recommend flushing between 45-60k miles.
I used Morande Acura in Berlin and so far have had pleasant experiences, both sales & service. By the way, the rep. that sold us the car in 4/02 is still there!
Thanks for everyone's input.
G35C033
The tranny fluid flush is not required at the 30K service. It's *recommended* but not required even at the 60K service. It's definitely not a bad idea at 60K, just not required. I changed my tranny fluid in my '97 Maxima for the first time at 100,000 miles. The fluid was just as pink as the day the car was new. My '02 TL-S's tranny fluid was nice and pink at 24,000 miles. 700 miles later it was brown and 100 miles after that the tranny failed. A modern car with 30K miles should not have dirty tranny fluid, period--unless there is some other underlying problem. And knowing the history (firsthand) of the tranny problems of these cars, I would be suspicious of your tranny at this point.
9th Gear
I'll check the fluid in another few thousand miles to see if it's changed color and go from there, hoping for no interim surprises!
G35C033
G35C033
Morande acura seems to be pretty good. I use Schaller Acura for convenience. I really like their service, although I did not buy my TL there.
Good luck with your wife's TL
9th Gear
G35C033
Thanks for the feedback on Schaller; i'll use them as a back-up.
G35C033
DiamondJoeQuimby
09-10-2015 11:40 AM
Mike Bertram
09-10-2015 09:27 AM
asahrts
09-04-2015 05:55 PM
