01 seat harness diagram
can anyone give me a diagram for the seat harness for the 99 and the 01. cause i wanna put my black seats into my car but i heard the 01 harness will plug in but the seats wont work since the pins are in different places
can anyone help me!!! the 01 harness has like 10 wires and my 99 only has 7 wires for the seat. can anyone help me repin the pins so i can use my new black sets.
dont know what would be different other than the side airbags. The 99-01 used the same seat i thought. Ill look in the manual in the am and see what i can dig up.
The passenger side and drivers side should be different.
Passenger side. (gray connector-99)
1...23
45678
1). blank
2). Grn/Red- Seat Heaters
3). Grn/Blue- Seat heaters
4). Blk (g581)- ground
5). Red- Fuse 5 passenger side
6). Black- (g581)- ground
7). Wht/Red- Fuse 6 passenger side
8). Blk- (g581) ground
00-03 harness
12.....34
5678910
1). 00-01 Blu/white (srs)
02-03 male-blue/wht
female- yel/blu- (circut s53)
2). Blk- (g581) - ground
3). Grn/Red- Seat heater
4). Grn/Blu- Seat heater
5). 00-01 Blu/grn
02-03 Male- blu/grn
Female blu (srs)
6). Blk (g581)
7). 00-01- Red
02-03 Male-Red
Female Red/yellow- (fuse-5 passenger side)
8). Blk (g581)
9). white/red- fuse 6 passenger side
10). Blk (g581)
1...23
45678
1). blank
00-03 harness
12.....34
5678910
02-03 male-blue/wht
5). 00-01 Blu/grn
02-03 Male- blu/grn
Female blu (srs)
6). Blk (g581)
7). 00-01- Red
02-03 Male-Red
8). Blk (g581)
10). Blk (g581)
drivers side there are 3 different harnesses. The 99-01 share the same the 02 is different and the 03 is different from both.
if you dont have them yes. The main differences seem to be the wires for SRS.
Thats all there is to connect.
is there a somewhere i can buy a harness connector to plug into my car harness so i dont have to hack my stock wires. i really dont want to cut it after i think about it
No. You cant buy it. Dont cut it, repin them. The wires come out. There is a little tab that holds it into the harness. With a small eye glass screw driver or small nail pry up on the tab and pull the wire out.
You must be careful doing that- if you damage the terminals they may not fit back into the connector or will not stay in place. Take a good close look at the connector to see how to pry the terminal retaining tabs first. A magnifier (like an optivisor) may help.
i need the pin points for the driver now. the one on top was for passenger. i accidently unpin the driver seat and putted it into the passenger and now that i unpin the passenger side i dont know which wire goes to which for the driver
5678910
1). 00-01 blu/red (srs)
2). blk (g551)
3). blk (g551)
4). wht/blu (seat heaters)
5). blk (g551)
6). red/blu (circuit 177)
7). red (fuse 2 passengers)
8). blk (g551)
9). blu (fuse 4 passenger)
10). wht/red (seat heaters
5678910
2). blk (g551)
3). blk (g551)
5). blk (g551)
8). blk (g551)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
