00 TL won't down shift
i just bought a 00 TL with 132k milages....i was using sport mode...and cruising at 50 miles..and want to down shift...but....the trany don't want to down shift....up shift perfect.
It wont let you downshift to avoid damage to the transmission.
You can downshift if the speed & rpm are right.
there are set speed/rpm limits the computer will allow/deny a downshift
If the requested shift would put it in redline- the shift is denied
the dash display will flash the requested gear then go solid in the current gear
reduce speed/rpm and try again
Beware of wearing 2nd and 3rd gear clutch packs--downshfifts put excess wear and heat in them= trans failure
Please tell us what gear and speed you were attempting- see if there is another issue for you to be aware of
hint: reading the threads in the main area plus Problems and Fixes section will teach you most of the TL-s weak points and things to watch for- maitenance to do etc
welcome and congrats on your purchase
register with acura,, and the owner book is online
http://owners.acura.com/registration...erstepone.aspx
but i think its more respectful for all the work / help you do for us.
Say your in a big complex that (aka: the gym/national training center that i go to every other day) you have to travel over a lot of speedbumps... for about 2 min.
Instead of letting the car shift from 1-3 between bumps, is it / would it be better just to use tiptronic / SS and keep it 2nd the entire time? - and just keep the speed down to say 20km/h / 10+ ish mph?
Ive tried this last night and i can make it through the entire thing in 2nd without downshifting and the speed and rpm are perfect.
Is what im doing better for the clutch packs and can i apply this logic to other similar scenarios?
SidhuSaaB
05-30-2020 12:40 AM
Hines57
09-24-2015 01:58 PM
