$9.44!!!!!!!!!!!!!!!!!
Old Oct 17, 2005 | 07:43 AM
RickRoush03's Avatar
RickRoush03
WHAT A RIP OFF!! Thats how much i am going to pay for a tiny ity bity little clock light. i only paid $5.50 for a 500watt bulb for my work light, and this shitty litttle light probably isn't 1/2 a watt. No parts store carries it, just acura. oh well, at least i can put my dash back together.
Old Oct 17, 2005 | 08:22 AM
bkzjimmy's Avatar
NiGhT rIdEr
i paid like 1.75 like a year ago. i still havent changed it tho.
Old Oct 17, 2005 | 12:13 PM
Check this post.
https://acurazine.com/forums/ramblings-12/car-underworld-123937/
Old Oct 17, 2005 | 12:19 PM
badazzTL's Avatar
Peach Tea
I was getting ready to go to Acura one day this week to see about replacing my clock light. I guess I'll give the Radio Shack bulb a try. Sucks I have to take apart my dash again though, I just did that like 2 or 3 weeks ago
Old Oct 17, 2005 | 12:37 PM
RickRoush03
now i totally forgot to check radio shack, went everywhere else but, i'll call them now! thanks!!
Old Oct 17, 2005 | 12:43 PM
RickRoush03
well just called, one didn't have it, the other showed them having it but couldn't find it. oh well, i am not waiting around, i'll get screwed by acura and press on, but good to know about radio shack for next time.
Old Oct 17, 2005 | 12:57 PM
If you want you can just buy the bulb online. Basically there are 2 different bulb size on our dash. Size T1 3mm and T3 5mm.
The one from Radio Shack is the T1 3mm size, it will fit all the dash switch, The clock use a bigger bulb 5mm bulb but I replace the bulb with the 3mm without any problem, the bulb is just as bright.
if you really want to keep the bulb the same size then you will have to special order from radioshack or some other places online.
here's are some links you might be interested.
5mm bulb
3mm bulb
Old Oct 17, 2005 | 01:08 PM
Well tell that dude at Radio Shack that the bulb is in the electronic tray where they sell transistors and resistors. They come in a package of 2.
Old Oct 17, 2005 | 04:06 PM
jpadilla's Avatar
Its not just the bulb, acura also give you the socket. I tried to go with the radio shack route when I replaced mine but it was a hassle trying to get it to fit into the socket and twist the wires around, etc. I finally broke down and bought the one from acura ... simple swap vs the radio shack rigging.
Old Oct 17, 2005 | 05:06 PM
mr.motoring's Avatar
checkmate...
Aww, cmon! From the numerous '!' in the title, I thought someone drove away from a dealer with a spankin new 6MT A-Spec laden TL for just that sticker price. What a letdown.
Old Oct 17, 2005 | 05:52 PM
dnd2984's Avatar
I wonder how much the clock cost. Mine looks like this....
[img=http://img419.imageshack.us/img419/2056/clock4wu.th.jpg]
Old Oct 17, 2005 | 06:01 PM
badazzTL's Avatar
Peach Tea
that sucks.
Old Oct 17, 2005 | 06:11 PM
fsttyms1's Avatar
Looks like its about 44.00 to 52.00 depending on the dealer
Old Oct 17, 2005 | 07:22 PM
RickRoush03
ok, spent the money and got the bulb which came with the socket from the dealer, like $10.25. A new clock, b/c i did inquire about this once, was like $80 i think, i almost chocked when i heard, look on ebay, thats what i did. got it for $25.
Old Oct 18, 2005 | 10:41 AM
may be I'll post some Pics on how to do this. I just blow one bulb, so hopefually this weekend I'll get to it.
Old Oct 18, 2005 | 12:09 PM
RickRoush03
How to do:
1. Remove 2 screws above steering wheel
2. Pull upper dash trim out carefully
3. Unhook all the wires behind the clock, temps, and hazard lights
4. Unscrew the 2 phillips screws holding the clock in, clock will come out
5. Looking behind the clock, there is a white circle with a phillips screw looking socket, take a tiny, skinny flat head screw driver and turn about 1/4 counter clockwise turn, i think or just the other way, she'll come right out
6. If you got a bulb from acura, pop it in and go in reverse order to put car back together, if you got the bulb from radio shack, undo the prongs, pull bulb out of socket, put new bulb in, rerun the prongs on the socket
7. Done!
Old Oct 18, 2005 | 02:26 PM
vntperformance's Avatar
60mph and then 3 honks?
One of the digits was out on my clock and I took mine into the dealer... I was right at 49k miles and they replaced the clock under warranty....too bad I just hit 50k miles.
vnt
Old Oct 20, 2005 | 04:58 PM
stiletto's Avatar
I am sure you tried whacking the dash right above the clock area to see if the light came back on, right? I know I went like this (no clock light) for months 'till I heard about that tip and voila! it worked like a charm...
Peace.
Old Oct 20, 2005 | 11:53 PM
badazzTL's Avatar
Peach Tea
Peace.
ahaha no way! how hard and exactly where do you "whack" it? I'm gonna try this tomorrow
vp911
176
Jan 18, 2025 08:10 AM
rets
987
Jun 8, 2020 07:01 PM
