RL 2006+A-spec+H&R... 235/50/18??
Need advice!
I have a 2006 RL with A-spec shock absorbers and H & R springs.
I want to buy winter tires in a 235/50/18 size.
Would not hurt if this underestimation of the arch?
It will work, a little smaller diameter, difference of 2.2% which will throw off speedo, odo and probably be OK with the AWD software. Depending on where you are, I hear the killer snow combination, using your old 17's is 225/55-17. No diameter difference from stock, and much cheaper!
Good luck whatever you do...
I also have the Michelin X-ice 235-55-17 was my winter-package. No clearance issue, i think it might be even high then my 245-45-18 summer-package.
*Kurenev- plz, let me know how much the H&R spring brings the clearacne down? and how it drives in the snow, and if ur A-Spec Lip is getting f-ed up?
