Is it possible to go with 255/50/17 on stock tires
The Doctor
Tirerack only lists 2 kinds of tires for stock substitution, for high performance all-season. If I go 255/50/17 or even 255/45/17 I get more choices. Has anyone tried different tires in different ratios yet?
According to an online tire size calculator, if I go with 255/50/17, when my speedo reads 60 mph, I am actually going 60.9 mph.
If I go with 255/45/17, when my speedo reads 60 mph, I am actually going 58.6 mph.
The small change in width to 255 mm will give you a little more rim protection and should fit fine IMHO.
I have read that you want to keep the diameters within 2% maybe 3%, otherwise braking and handling can be affected adversely. I don't know if it is true, but that would say the lower profile choice is way over spec, or I guess in this case, under spec.
The other thing you will do, of course, is through off the speedometer and perhaps more importantly, the odometer.
1fatcrxnem1
22
06-01-2018 01:23 AM
