Need Help With Rims
Null and proud of it
Need some help "whit" wheels? Here ypu go.
Your car uses a 5x120 bolt pattern. These TLX wheels use a 5x114.3 pattern, like most cars. IDK why the 4G TL has a 5x120 as no other. Honda/Acura sedan I know of uses the pattern... Kidna strage....
Anyway, you will need an adaper and you could make them fit if you want to....
I hope this helps. I like the whhels you're looking at, BTW!
These are some wheels another member is selling. You can see how they're 5x120 in the description.
https://acurazine.com/forums/market/978063
All u have to check its the offset
The oem rims are +55 offset
And mine are DCT racing +35
So I made the purchase for 20×8.5 +35
The Lugs slot are 5x120mm
Using tires 245/35/R20
Lugs size 1.5
None spacers just like a says Plug N Play
I did nothing bro I will post all the info here
Lugs size 1.5
Lugs size 1.5
