lower control arm bushings
Hi All,
I wanted to say this is a great forum with the wealth of information. I'm unfortunately not able to find any part #'s on the lower control arm bushings. I had gone in for an oil change and I noticed by bushings are cracked.
I've located these #'s below:
51360-SJA-023 -driver side
51350-SJA-023 - passenger side
1. My question to all isn't there a way just to purchase the bushings on its own w/o buying the whole control arm.
2. Are all bushings a universal size? I know this may sound like a stupid question.
3. If it is possible could someone give me the part #?
I'd appreciate any help that can be given. Thanks ahead of time to all.
Did you use the search function at all? I'm guessing not because, had you searched in this forum for "control arms," you would have found the answer you're looking for in the 4th thread down from the top on the search results:
https://acurazine.com/forums/showthr...t=control+arms
Yep, I read it carefully. I'm screwed. I have no choice but to replace the lower control arm. Damn it. Thanks for the information BDoggPrelude.
joflewbyu2
Oct 8, 2015 11:16 AM
