low cost tire..
Remove Continental
ContiExtremeContact
Blackwall
Front & Rear
$154.00
Ultra High Performance All-Season
96W Load Index 96 = 1565lbs (710kg) per tire
Speed Rating “W” = 168mph (270kph)
None
Probably - 7.8
8.4
8.5
8.1
8.6
8.2
7.9
7.1
6.9
8.1
7.9
7.8
Treadwear: 400
Traction: AA
Temperature: A400 AA A
1565 lbs.
44 psi
10/32"
25 lbs.
7.5-9"
8"
9.6"
N/A
26.7"
791
Country of Origin "DE" = GERMANYDE
Warranty Info
Reviews
Test Results
Survey Results
Continental
ContiExtremeContact
Front & Rear
$154.00
In Stock
1 2 3 4 5 6 7 8 Road Hazard: N/A (set of 4)
Remove Goodyear
Eagle GT
Blackwall
Front & Rear
$143.00
Buy a set of four and get a $20 rebate by mail.
Varies
Probably - 8.0
8.8
8.5
8.5
8.7
8.4
7.3
6.2
6.3
8.0
7.8
7.8
Treadwear: 400
Traction: AA
1565 lbs.
51 psi
10/32"
30 lbs.
7.5-9"
8"
9.6"
N/A
26.7"
784
Country of Origin "US" = UNITED STATES OF AMERICAUS
Warranty Info
Reviews
Test Results
Survey Results
Goodyear
Eagle GT
Front & Rear
$143.00
In Stock
1 2 3 4 5 6 7 8 Road Hazard: $68.64 (set of 4)
Remove Kumho
Ecsta ASX
Blackwall
Front & Rear
$136.00
100W Load Index 100 = 1764lbs (800kg) per tire
30,000 Miles
Probably - 7.6
7.9
8.0
8.1
8.6
8.2
6.6
5.4
5.7
8.2
8.0
7.5
Treadwear: 420
Traction: AA
Temperature: A420 AA A
1764 lbs.
50 psi
10/32"
30 lbs.
0-0"
N/A
N/A
Country of Origin "KR" = KOREA, REPUBLIC OFKR
Warranty Info
Reviews
Test Results
Survey Results
Kumho
Ecsta ASX
Front & Rear
$136.00
In Stock
1 2 3 4 5 6 7 8 Road Hazard: $65.28 (set of 4)
ContiExtremeContact
Blackwall
Front & Rear
$154.00
None
Probably - 7.8
8.4
8.5
8.1
8.6
8.2
7.9
7.1
6.9
8.1
7.9
7.8
Treadwear: 400
Traction: AA
1565 lbs.
44 psi
10/32"
25 lbs.
7.5-9"
8"
9.6"
N/A
26.7"
791
Warranty Info
Reviews
Test Results
Survey Results
Continental
ContiExtremeContact
Front & Rear
$154.00
In Stock
Remove Goodyear
Eagle GT
Blackwall
Front & Rear
$143.00
Varies
Probably - 8.0
8.8
8.5
8.5
8.7
8.4
7.3
6.2
6.3
8.0
7.8
7.8
Treadwear: 400
Traction: AA
1565 lbs.
51 psi
10/32"
30 lbs.
7.5-9"
8"
9.6"
N/A
26.7"
784
Warranty Info
Reviews
Test Results
Survey Results
Goodyear
Eagle GT
Front & Rear
$143.00
In Stock
Remove Kumho
Ecsta ASX
Blackwall
Front & Rear
$136.00
30,000 Miles
Probably - 7.6
7.9
8.0
8.1
8.6
8.2
6.6
5.4
5.7
8.2
8.0
7.5
Treadwear: 420
Traction: AA
1764 lbs.
50 psi
10/32"
30 lbs.
0-0"
N/A
N/A
Warranty Info
Reviews
Test Results
Survey Results
Kumho
Ecsta ASX
Front & Rear
$136.00
In Stock
Kumho or Hankook are low cost tires. To some extent, you get what you pay for. In the case of Michelin and Pirelli, you are paying for huge advertising budgets.
I know a guy in the local BMW club who runs summer Hankooks on the track. Cheap, and reasonably good for what you get. After 30 minutes of high speed, he says you can really feel the tires getting greasy, and you have to back off. I rode with him for over 45 mins flat out, at Summit Point and I was impressed!
Korean products are getting better and better, at a rate much faster than Japanese products did when they were first introduced. Remember the first Hyundais about 20 years ago? Look at them now, especially the Genesis.
The Generals are rated well. Only issue I have found is that their contact patch is very narrow compared to other makes. Sometimes up to 1" narrower so 265's would be closer to 245's.
Many seem to like Falken 452 tires.
Nankang/Sunny tires are the lowest priced tires (under $100) but they have a large % of natural rubber in them which means they wear out very quickly.
onlinetires.com have the lowest prices around and run free shipping on a few tires here and there. Worth checking out.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
