How much for new Brakes & Calipers
Old 05-14-2010, 02:27 PM
Raider's Avatar
Dealer just quoted 1185 for brakes and 1150 for new calipers.....scam and a half....where should i take my 05 RL instead in boston area without getting charged an arm and a leg?
Old 05-14-2010, 02:33 PM
Received 16,266 Likes on 11,974 Posts
Do it yourself?
Old 05-15-2010, 11:49 AM
rtr
RL owner
rtr's Avatar
why would you need calipers???
Old 05-16-2010, 02:42 PM
Joe's06AcuraRL's Avatar
Just did all 4 brakes and all 4 new rotors for $400.00.. Go to a local mechanic is usually ur best bet and get OEM parts
Old 05-17-2010, 08:01 PM
Ballinger's Avatar
Rotors I can understand, but the massive Advics calipers are about the most gnar you're gonna fit in there. Worst case, have them powdercoated and the logos burred. Thing is, you can swap the rotors yourself if you can jack the car up (save yourself from agony by not-using the oem convenience jack).
Old 05-18-2010, 05:56 PM
2005 RL
racerrl's Avatar
Are the front calipers manufactured by Brembo or Advics? I've heard both.
Old 05-18-2010, 06:52 PM
Chas2's Avatar
I have read on nsxprime that the calipers have Advics stamped on the back.
Old 05-18-2010, 09:40 PM
037's Avatar
I've stuck my head in the wheel well to confirm it says Advics, I was pretty pissed.
Old 05-19-2010, 05:29 PM
CarbonRL's Avatar
If you don't mind a 45 minute drive to Worcester, try AutoPro Import Repair. Great, trustworthy owner/mechanic (Ted) and extremely reasonable prices. He will give you the straight scoop on what you really need.
http://www.autoproimportrepair.com/
Old 05-19-2010, 05:35 PM
037's Avatar
I'm wondering if the front 4 piston brakes can be fitted to the back...I assume rotors would need to be swapped out. Would it be possible otherwise?
I've read up on the Spoon RL and the article said it had 4 pistons on both ends...
Old 05-19-2010, 10:27 PM
Chas2's Avatar
There was an article that said that it had 4 piston calipers on the rears. There was something else somewhere that contradicted that. There was someone that actually had the car in the dealership floor, but I cannot remember if he spoke about the brakes. Bottom line, it is uncertain what the rears were fitted with based on internet chatter and articles.
08_UA7_Gr33k
02-11-2016 02:17 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
Quick Reply: How much for new Brakes & Calipers
