Help with tires for A-Spec wheels
Hi...
I am depaxing my RL that came with PAX and I got a set of 18" A-Spec wheels. HOWEVER, I just got off the phone with Costco trying to get a set of Michelin Primacy or Pilot Sport A/S Plus in 245/45-18 and they said they can't put those on my wheels because the Load Index of those tires are 96 while the stock 17s with 245/50-17 are 98 or 99 and they can't replace originals with lower load index tires.
Have you guys ever heard of this??? In fact, I asked and they couldn't find ANY Michelin 245/45-18s that would satisfy the load index requirement of the original 17s. What up with that???
Any insight would be greatly appreciated!
I even mentioned these were genuine Acura A-spec wheels and not aftermarket. (I knew mentioning PAX would cause even bigger problems, so I told them I have a standard RL). In any case, they said they couldn't find any Michelin tires in 245/45-18 that would satisfy the load index requirement that the original 17" provided.
When I asked WTF if Acura sells them this way, why can't I get the same tires. Then they wanted to know what the original tires were that came with the A-spec wheels. Of course, I didn't know so I couldn't answer that question. Told them I would call them back after I looked.
What do you guys think? My guess is the a-spec tires have the lower load index and it's not an issue with Acura. Costco is just being anal and stupid. Does anyone have any suggestions on what I can say to convince them?
245-45 zr18 96 y
I have the Acura A spec wheels and Michelin Pilot Sport A/S. 245/45ZR1896Y.
When you buy the A spec wheels, you are suppose to get an additional page which they glue inside your owner's manuel, which states:
"RL -Tires Size, Be sure to use only the following tire size ...245ZR1896V"
I use to buy tires at Costco, but no longer as they enforce stupid rules, like the one you are seeing.
Plastics
05 Acura RL silver
Plastics
05 Acura RL silver
Plastics
05 Acura RL silver
Plastics
05 Acura RL silver
Thank you very much to Plastics for faxing me a copy of the Acura doc that states the proper size of tire for the 18" accessory wheels for the RL. Since it is an Acura doc and it says 245/45-18 96 load rating, Costco shouldn't have a problem I HOPE!
Y not try Tirerack? that's where I got mine... it's the cheapest anywhere... the goods (4X Michellin Pilot Sports A/S for A-Spec rims) was at my door steps 1.5 days after I place the order
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
nuldabz
09-03-2015 05:49 PM
