Just pulled the trigger on my first RL. Have owned several Tls and used HnR springs on all. Please does anyone have photos of RL with HnR sport springs on stock 17" wheels. Thank you...
That's not my car. That is Blazing GT's which is sold now. A lot of his photos were lost, but that is the only setup he ran with 17" wheels.
As for the fog lights, the bulbs are H11. In order to get a pure white light, you will need HID bulbs requiring a ballast. For your cheapest reliable option, I would go with this. http://www.theretrofitsource.com/pro...oducts_id=3955
If you spec your tires correctly, all rims will give the same ride height. My guess is you get some scraping, but not a lot if your struts aren't old.
Blazing's car that I posted above hit an exposed man hole cover in a NYC construction site and cracked his oil pan. It certainly isn't a common concern because the hole was raised above reasonable height, but it probably wouldn't have happened on stock springs. It would have hit a Corvette though.
Here's my ride. I clipped the fronts one ring to lower it more in the front and make it even with the rear. I have 20" Niche Targas sitting on my balcony waiting to installed as soon as the USPS man arrives with my new TPMS sensors.
