Do alignment specs change with A Spec suspension?
Does anyone know if the alignment specs change with the A-Spec suspension? The last page of the A-Spec installation instructions had alignment specs but I don't have them anymore. The manual lists the following for the stock alignment specifications:
Toe-in
Front: 0.00 in
Rear: 0.08 in
Camber
Front: -0 deg 8'
Rear: -1 deg 15'
Caster
Front: 2 deg 10'
If anyone still has the A-Spec installation instructions please let me know what the specs are on the last page. Thanks!
Toe-in
Front: 0.00 in
Rear: 0.08 in
Camber
Front: -0 deg 8'
Rear: -1 deg 15'
Caster
Front: 2 deg 10'
a, acura, alignment, aspec, guide, install, installation, instructions, rsx, spec, specifications, specs, suspension, tl, tsx
