clunk on front?
Old 01-18-2017, 04:56 PM
fuzzysig's Avatar
clunk on front?
is there a common problem on 2005 RL
I go over a bump and have a clunk from the front.
how can I tell if its sway bar end links or something else?
I replaced left wheel bearing lower control arm and upper control arm already and strut
all ball joints were blown out for some reason on driver side.
but sway bar links don't seem to be loose
and they are 50 bucks a pop. I don't want to spend 100 bucks and find out it wasn't the problem
Old 01-18-2017, 05:00 PM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
Inspect your motor mounts
Old 01-18-2017, 07:47 PM
fuzzysig's Avatar
going over bumps not when accelerating
Old 01-18-2017, 08:04 PM
projektvertx's Avatar
A clunk when going over speed bumps in particular is usually symptomatic of bad sway bar end links. I emphasize the word usually as suspension clunks I usually like to hear myself.
Old 01-19-2017, 12:00 AM
fuzzysig's Avatar
how can I check the endlinks?
I wiggle them but they seem to be ok no play when wiggle. but they have tension on them
Old 01-24-2017, 01:13 PM
fuzzysig's Avatar
ha got em
the balljoint on pass side was bad also
so far i found:
driver side shock lower control arm and bearing
pass side lower control arm ball joit
hopefully thats the end of it
projektvertx (01-24-2017)
Old 02-20-2017, 12:27 AM
fuzzysig's Avatar
finally suspension is fixed. very nice and smooth ride
now i hear all the whine from everywhere else and squeaks haha
rlx015 (06-18-2017)
Old 02-24-2017, 06:04 PM
7th Gear
MJSterling's Avatar
Talking
Now just crank up that sweet stereo
Old 04-04-2017, 11:57 AM
fuzzysig's Avatar
well this is annoying
3-4 weeks and the clunk is back along with many other noises lol
except this time theres no visible play in upper or lower balljooints since both lower ones were replaced
but the clunk is still there now only when I go over bumps at low speed.
the freeway issue is fixed with lower ball joints,
Old 08-07-2017, 09:31 PM
fuzzysig's Avatar
well this is crap
found the pass side lower ball joint bad again and driver side wheel bearing...
i replaced both with low mileage oem ones and now they are blown out again after few months
wtf acura. i feel like i own a bmw with this car srusly something is always breaking
Old 08-09-2017, 07:35 AM
teh CL's Avatar
Was the wheel bearing installed correctly? & your best bet definitely isn't used parts..
Old 08-09-2017, 07:42 AM
Received 16,260 Likes on 11,971 Posts
it's a 12 year old used car.
12 year old cars are needy as fuck, regardless of make and or model.
i'd rather spend on maintenance than finance a car.
a few grand a year vs $25k-30k for 5 years with interest. (and i'm being generous, we all know it'd likely be a 72 month loan to eek out the least monthly payments)
Old 08-13-2017, 01:06 AM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
man your RL seem like give you alot of trouble, how many miles now and when you bought it?
