Ball joints
Old May 13, 2015 | 04:30 PM
nynruas's Avatar
Ball joints
2005 RL: squeaking like crazy up front, when driving, turning, over small and big bumps. Dealer says $300 for upper control arm w/ ball joint and $655 for lower control arm w/ ball joint. I've been able to find a press in upper ball joint but no luck on finding a lower ball joint. Any help?
Old May 14, 2015 | 01:01 PM
ExcelerateRep's Avatar
Former Sponsor
We typically only sell the front upper ball joints/control arms as they are the ones that adjust camber and alignment. You'd probably be better off with an oem lower balljoint. We do have the upper ones available for $66.88.
Ingalls Alignment Kit - Excelerate Performance - Japanese and European Performance Specialists!!
Old May 22, 2015 | 02:57 PM
hotdealdave's Avatar
Could a bad control arm bushing or ball joint be causing the "clunking" I hear from the front end when braking hard or when I go over bumps? I don't think it's the motor mount because I replaced that with a solid one about a year ago.
Old May 23, 2015 | 10:14 AM
oo7spy's Avatar
95% sure that would be a failed strut.
Old May 28, 2015 | 03:35 PM
dahatter's Avatar
What do you think would cause a clicking sound when I'm turning the wheel and driving?
Old May 28, 2015 | 04:38 PM
NathanJax's Avatar
That's usually a cv axle
Old May 28, 2015 | 05:10 PM
dahatter's Avatar
Thanks for the info.
jblessing
Aug 8, 2018 09:43 PM
marcelft
Jul 10, 2018 06:17 PM
Brandle34
Sep 23, 2015 07:20 PM
0opie
Sep 22, 2015 04:15 PM
V-tecAc
Sep 21, 2015 09:25 AM
