Sorry guy, this is a one off Acura RL A-Spec Concept Car with MDX like 20x8 custom wheels. Never sold. The MDX wheels do not fit the RL because of the large calipers.
what size spacers did u get and did it rub? im feeling it more with the drop.
Honestly idk the size of the spacer but I can tell you it was just the right amount needed. Nah no rubbing at all. These wheels are gone just waiting to put another set of wheels on. A local is selling a set of 2010 rl wheels. Kinda interested.
For anyone who is still looking for information on the MDX wheels:
I measured with a caliper, used old crush washers to imitate a spacer, and found that a 7mm spacer would probably work with a bit of sanding to the brake caliper.
For me, I found 7mm wouldn't be considered safe enough to run on stock studs since the amount of complete lug turns was decreased.
I then found the extended studs a member previously made a post about which are 10mm longer than stock. With that, I ordered some custom 10mm hub centric spacers.
Here's how it looks lowered with 10mm spacers on 245/40/19 tires. Note: There is no rubbing (even with a heavy load in the back) or issues when fully turning. Someone else with the same wheels told me they used some 15mm bolt on spacers and had no issues making a full turn but I prefered slip on spacers.
