Jones's 05 RL Celestial Silver - 150k And Still Kicking
Never taken any decent pics of my RL so here you guys go, 155k miles and still kicking hard.
Only thing I've had to replace recently was the alternator which was done at Lewisville Honda, and the headlight bulbs which are now Xenarc 4300k.
Maintenance history...
Date Mileage Location
01/16/2016 153,029 Vandergriff Acura
Brake master cylinder replaced/repaired
Rate Service:
02/06/2015 149,362 Lithia Honda of Abilene
Vehicle serviced
01/27/2015 Avis Lube #116
Maintenance inspection completed
Oil and filter changed
Safety inspection performed
Cooling system checked
Drive belts checked
10/02/2014 Lithia Honda of Abilene
A/C system serviced
Tire condition and pressure checked
09/03/2014 144,733 Lithia Honda of Abilene
A/C system serviced
A/C refrigerant recharged
A/C system flushed
07/18/2014 143,822 Tom's Tire Pros - Clack
Vehicle serviced
06/05/2014 142,847 Lithia Honda of Abilene
Tire repaired
05/21/2014 142,405 Lithia Honda of Abilene
Electrical system checked
04/25/2014 141,784 Lithia Honda of Abilene
Wiper(s) replaced
Emissions or safety inspection performed
01/10/2014 136,051 Lithia Honda of Abilene
Battery/charging system checked
Wiper(s) replaced
Four wheel alignment performed
Battery replaced
10/23/2013 132,262 Lithia Honda of Abilene
A/C system serviced
09/18/2013 130,560 Lithia Honda of Abilene
Tires rotated
Brakes checked
02/22/2013 121,672 Lawrence Hall Chevrolet
Vehicle serviced
01/05/2013 121,296 Lithia Honda of Abilene
Tires rotated
Air filter replaced
10/22/2012 117,162 Lawrence Hall Chevrolet
Washed/detailed
09/13/2012 116,602 Tom's Tire Pros - Oak
Two wheel alignment performed
08/02/2012 115,453 Lithia Honda of Abilene
A/C system serviced
06/05/2012 113,863 Lithia Honda of Abilene
Four tires mounted
Headlight bulb(s) replaced
Battery replaced
06/02/2012 113,770 Avis Lube #116
Inspection completed
Fluids checked
Drive belts checked
03/28/2012 110,215 Lithia Honda of Abilene
01/19/2012 108,263 Lithia Honda of Abilene
Vehicle serviced
12/05/2011 106,129 Lithia Honda of Abilene
Water pump replaced
Timing belt replaced
Drive belt(s) replaced
Spark plug(s) replaced
12/01/2011 Texas
Registration issued or renewed
Passed safety inspection
Registration updated when owner moved
the vehicle to a new location
05/17/2011 98,436 Avis Lube #116
Fluids checked
Drive belts checked
12/29/2010 93,602 Pep Boys
Emissions inspection performed
Vehicle serviced
11/05/2010 90,031 David McDavid Acura of Austin
Recommended maintenance performed
Washed/detailed
Transmission serviced
Differential checked
Transfer case serviced
Air filter replaced
Driveshaft checked
Parking brake adjusted
Cabin air filter replaced/cleaned
Tires rotated
Steering/suspension checked
Differential fluid flushed/changed
Rear differential fluid flushed/changed
Transfer case fluid flushed/changed
Brakes checked
08/26/2009 74,937 Pohanka Acura
Tires rotated
07/09/2009 72,431 Midas
Battery replaced
03/27/2009 67,671 Pohanka Acura
Brake fluid flushed/changed
01/15/2009 63,767 Pohanka Acura
Washed/detailed
06/24/2008 54,358 Pohanka Acura
Washed/detailed
Liftgate/tailgate support strut(s) replaced
Shoulder seatbelt buckle replaced
Left front seatbelt buckle replaced
04/14/2008 50,774 Pohanka Acura
02/29/2008 48,723 Pohanka Acura
11/07/2007 42,761 Pohanka Acura
Washed/detailed
05/29/2007 34,680 Pohanka Acura
12/11/2006 27,064 Pohanka Acura
Vehicle serviced
07/07/2006 Pohanka Acura
Washed/detailed
02/15/2006 Pohanka Acura
Drivability/performance checked
01/04/2006 Pohanka Acura
PCM reprogrammed
Engine/powertrain computer/module reprogrammed
10/11/2005 Pohanka Acura
Washed/detailed
05/10/2005 Pohanka Acura
Vehicle serviced
03/23/2005 Pohanka Acura
Pre-delivery inspection completed
Wheel locks installed
and lastly the pictures
![Name: IMG_20160130_155939%201_zpsdcdkq4s2.jpg
Size: 214.5 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63339d1501363984-joness-05-rl-celestial-silver-150k-still-kicking-img_20160130_155939%25201_zpsdcdkq4s2.jpg)
![Name: 12630959_10154588000089741_1799227647_o_zpsuhcjgjol.jpg
Size: 73.8 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63340d1501363984-joness-05-rl-celestial-silver-150k-still-kicking-12630959_10154588000089741_1799227647_o_zpsuhcjgjol.jpg)
![Name: IMG_20160130_155746_zpst4fnshni.jpg
Size: 287.7 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63341d1501363984-joness-05-rl-celestial-silver-150k-still-kicking-img_20160130_155746_zpst4fnshni.jpg)
![Name: 12669861_10154588000034741_1754519670_o_zpsfcn0tbdr.jpg
Size: 67.3 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63342d1501363984-joness-05-rl-celestial-silver-150k-still-kicking-12669861_10154588000034741_1754519670_o_zpsfcn0tbdr.jpg)
![Name: 12636880_10154587999904741_2142532712_o_zpsml3eez76.jpg
Size: 83.9 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63343d1501363984-joness-05-rl-celestial-silver-150k-still-kicking-12636880_10154587999904741_2142532712_o_zpsml3eez76.jpg)
![Name: 12669755_10154588000234741_88025122_o_zpsppci7ova.jpg
Size: 93.7 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63344d1501363984-joness-05-rl-celestial-silver-150k-still-kicking-12669755_10154588000234741_88025122_o_zpsppci7ova.jpg)
![Name: IMG_20160130_154523_zpsyshtygn9.jpg
Size: 266.2 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63345d1501363984-joness-05-rl-celestial-silver-150k-still-kicking-img_20160130_154523_zpsyshtygn9.jpg)
![Name: 12656273_10154588000214741_285386048_o_zpsm9xnwhdv.jpg
Size: 69.2 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63346d1501363984-joness-05-rl-celestial-silver-150k-still-kicking-12656273_10154588000214741_285386048_o_zpsm9xnwhdv.jpg)
![](http://i686.photobucket.com/albums/vv221/jwjones91/2005%20Acura%20RL/12669885_10154588000139741_305344651_o_zpsmauor7fk.jpg)
![Name: 12632990_10154587999839741_213275536_o_zpsfg86zilg.jpg
Size: 82.7 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63347d1501363984-joness-05-rl-celestial-silver-150k-still-kicking-12632990_10154587999839741_213275536_o_zpsfg86zilg.jpg)
![Name: 12637124_10154588000159741_1734551143_o_zpsm7x9pg1r.jpg
Size: 63.3 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63348d1501363984-joness-05-rl-celestial-silver-150k-still-kicking-12637124_10154588000159741_1734551143_o_zpsm7x9pg1r.jpg)
Rate Service:
Vehicle serviced
Drive belts checked
A/C system serviced
A/C system serviced
A/C system flushed
Vehicle serviced
Tire repaired
Wiper(s) replaced
Wiper(s) replaced
Battery replaced
A/C system serviced
Tires rotated
Brakes checked
Vehicle serviced
Tires rotated
Air filter replaced
Washed/detailed
A/C system serviced
Four tires mounted
Battery replaced
Fluids checked
Drive belts checked
Vehicle serviced
Water pump replaced
12/01/2011 Texas
Fluids checked
Drive belts checked
Vehicle serviced
Washed/detailed
Air filter replaced
Driveshaft checked
Tires rotated
Brakes checked
Tires rotated
Battery replaced
Washed/detailed
Washed/detailed
Washed/detailed
Vehicle serviced
Washed/detailed
PCM reprogrammed
Washed/detailed
Vehicle serviced
![Name: 12656284_10154588000184741_969238312_o_zpsmdjtvuct.jpg
Size: 86.1 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63349d1501363984-joness-05-rl-celestial-silver-150k-still-kicking-12656284_10154588000184741_969238312_o_zpsmdjtvuct.jpg)
JJones91 (02-05-2016)
RL09 (03-17-2016)
It's neither wood nor a cover. It's technically plastic. You may be able to find one floating around the Internet for $200-400, but alas, they are discontinued and hard to come by. Otherwise, the '09-'12 RL came with them stock, but that will run you $600 for a discounted online dealer.
It's the best mod IMO.
Thanks! I try to keep it clean! Speaking of which I need to do tomorrow...
I love it! That and the wood shifter too![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
It really is I absolutely love it!
Exterior - Meguiars Quik Wax
Interior - Lexol Leather Conditioner
Exhaust - SOS Pads
Headlights - Rain X Headlight Restoration
To be honest I use the Meguiars Quik Wax on more than just the paint, I use it on the windows, engine compartment, and wheels. Works great I been using this stuff for years.
When I clean my car's I get in deep, once I start I don't stop until everything shines like a diamond in a goats ass
DJ 57 (03-18-2016)
I may not have all the fancy tools to detail my cars but I know how to make them shine just as good as the professionals ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
This was my pride and joy, 98 Mustang GT. Had 80k original miles, never left the state of Texas.
![Name: 20140215_122918_zpsz8frjvvh.jpg
Size: 107.0 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63132d1501362368-joness-05-rl-celestial-silver-150k-still-kicking-20140215_122918_zpsz8frjvvh.jpg)
![](http://i686.photobucket.com/albums/vv221/jwjones91/20120724_192924.jpg)
And the photoshoot it was in..
![Name: 1947862_10202734005744453_1537519493_n_zpscmsxxmmd.jpg
Size: 48.6 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63133d1501362368-joness-05-rl-celestial-silver-150k-still-kicking-1947862_10202734005744453_1537519493_n_zpscmsxxmmd.jpg)
![Name: 10006202_10202734007424495_647847115_n_zpsjfiokiuf.jpg
Size: 129.0 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63134d1501362368-joness-05-rl-celestial-silver-150k-still-kicking-10006202_10202734007424495_647847115_n_zpsjfiokiuf.jpg)
![Name: 1926764_10202734014384669_119000361_n_zpsmfbq1xqa.jpg
Size: 75.5 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63135d1501362368-joness-05-rl-celestial-silver-150k-still-kicking-1926764_10202734014384669_119000361_n_zpsmfbq1xqa.jpg)
![Name: 1798626_10202734014344668_56622060_n_zpsc7ymlxbw.jpg
Size: 80.8 KB](https://acurazine.com/forums/attachments/2g-rl-photograph-gallery-91/63136d1501362368-joness-05-rl-celestial-silver-150k-still-kicking-1798626_10202734014344668_56622060_n_zpsc7ymlxbw.jpg)
God I miss that car...
The green one? Not much, was more for show.
I took out the 215hp 4.6L and swapped in the 4.6L from the 04 GT, got 260hp out of it, then tuned it, did Borla exhaust with a prochamber, went with 3.73 gears, 275 Nittos up front, 315 Nittos in the rear, and that's about it, just a fun good looking Mustang.
projektvertx (02-18-2016)
DJ 57 (03-18-2016)
Washed/detailed
Air filter replaced
Driveshaft checked
Tires rotated
Brakes checked
[/IMG][/URL]
Washed/detailed
Air filter replaced
Driveshaft checked
Tires rotated
Brakes checked
[/IMG][/URL]
it has a 15k mile oil change interval i belive, transfer case and trans are 30k i think...
RL09 (03-17-2016)
Fk no!TheyldstroyEvrthing
Very minimal, not even enough to even call it drone lol. The mufflers are located at the exhaust tips so the majority of the exhaust noise is directed right out of the exhaust tips. Had I removed the resonators would be a completely different story lol
projektvertx (03-18-2016)
Sweeet sound. sports car now. And the engine sure can do it.
I think my neighbors would kill me if they heard me do that.
