JDM Headlights Installed!
The following 2 users liked this post by Wooodis:
kcjohnnyboy (07-31-2018),
RL_Coastin (12-19-2016)
Did you swap around the projector so it doesn't blind oncoming traffic with the wrong cut off pattern? Also, what did you do about the blinker bulb not fitting?
The following 2 users liked this post by NathanJax:
projektvertx (12-18-2016),
teh CL (12-18-2016)
RL09 (12-18-2016)
To me, the amber color draws your eyes to the corners of the car. Without them, the front end appears wider. And it now draws more attention to one of the most luxury looking front grille Acura has ever made.
MrG4Life (12-22-2016),
oo7spy (12-23-2016)
WHEELS! but I don't know which type of wheels I want yet, so it wont be for awhile.
I think it looks really really good. Not sure I would spend the money replacing mine if I had an RL, but your oem headlights looked a little on the faded side so I think it was worthwhile. I really like the little LED or white lights in the corners where the ambers were.
I tied to write a post the other day, but couldn't find the right words. This sums it up very well.
Yes they are. That's why I asked that question. He said he would "raise them" in post #7, but I'm hoping he will lower them so it doesn't blind oncoming traffic. That's the problem with purchasing these, as they will be higher to all oncoming traffic ALWAYS... The projectors need to switched so it's like your pic...
After installing these new headlights in my car and swapping out the front signal plugs and sockets I come to find out that one the plugs doesn't work.. I checked to see if power goes through the wires (Which it does), but when I check it from the other end (part that goes into the bulb socket) theres no power. So something is is wrong with the plug. Is it possible to directly connect the bulb socket to the wires?
I already went to Honda and Acura dealerships to see if they have a spare part but to no avail.
I believe the wires in the plug lead directly to a metal prong. Not 100% sure, but I can't imagine it being different. If so then you should be able to wire them directly. I would try fixing the plug first. Probably dirty connector, loose, or bad wires.
I think it depends on the color of the car as well. I think its too striking of a contrast with the WDP but I have them on my CGP and I am not offended at all and they blend well with my burnt orange calipers
