XM Radio reset in Trunk?
Old Mar 20, 2011 | 07:01 PM
zRLmarine's Avatar
Hello, was wondering if there is a post on how to reset the xm control that is located in the trunk?
i looked and of course couldn't find it.
thanks.
Old Mar 21, 2011 | 07:49 PM
HEAVY_RL's Avatar
You can unplug it, the power is in the harness... what are you trying to accomplish?
XM can also send a reset signal if its a service issue.
Old Mar 21, 2011 | 09:19 PM
zRLmarine's Avatar
something is wrong with the XM, when i leave it on any channel for an extended period of time (cough 10minutes) it will stick and stay on that channel if you try to change the channel...
other times it will take a few mintues for the xm to even turn on recieve any signal.
never has happened before.
no im not in a new place, not under a bridge.
i will call XM and have them reset signal, but i know guys have had luck unplugging the hardness then recontecting it.
Old Mar 22, 2011 | 09:28 AM
HEAVY_RL's Avatar
I would do both... go in the trunk on the left side and pull the harness then call XM... hell you might get a free month if you complain enough.
Old Mar 23, 2011 | 03:13 PM
zRLmarine's Avatar
i will do both when i have some time. ohh i know all to well that complaining will get me a free month
complained about 10 times when i forst got the car and the battery was low which was causing the XM to always flake out
dirleton
Aug 6, 2024 08:19 PM
baelim
May 10, 2018 09:53 AM
Jul 16, 2017 07:33 AM
jmaxima03
Sep 27, 2015 10:22 AM
