Video: My Custom Media Center using NavTool and USA-Spec
Hi guys, I kinda haven't been active since school has started for me, along with work and student organization. A couple months ago I basically ripped my RL apart did a bunch of sound proofing, cleaning of the car, and installing a bunch of after market stuff including the NavTool Video Interface unit and the USA-Spec XM Integration unit. I also became creative with a cheap media player unit that you would usually use with your TV to watch videos and play music off of a SD card or USB stick. Here is a little video of my setup and I will post links to the products I used incase you are interested in doing a similar setup. I know a couple of you already have the NavTool + USA Spec so this would only cost you around $60 to achieve a similar setup.
Video is in HD so I would maximize the video to see it really well.
Here is some of the basic things I used that you would need:
NavTool
http://www.navtool.com/acurarl3-1.aspx
USA SPEC PA15-ACUxI:
IncrediSonic Media Player:
Transcend 16GB SD Card:
NavTool
Nice setup, its what I'm aiming for but I would use the media player with either the autotoys unit i mentioned in my thread or with a Navtool n Grom USB unit combo. Playing videos off iphone is a pain. I hope that little media player can read more than 1 file format.
Also Yes you are right, getting videos to play off iDevices are painful first you have to convert...then sync..etc, this way all you do is copy the file to the SD card and you are Done, saves you like 5 hours.
Very, very cool. I am particularly interested in the switch for the Navtool. How did you figure that out? Is it listed in the install instructions? I assume you had to get those at radioshack or something, right?
Yes I bought the switch from radio shack. NavTool includes a momentary push button switch in the NavTool package so basically I just bought this instead and wired it into my center console. The installation instructions explain it but I believe there is a 12V+ Input line that you connect this to and the other terminal goes to ground (or 12V) can't remember which one.
you basically have the same set up as me, short of the inverter and media player.
I ran the video cables to the middle console so I could plug in what ever I wanted with extended cables.
This is awesome. I'm new to the Acura world w/ my 2013 RDX. Before with my 2008 IS 350 I had the Vais Technology SL2Vi which allowed ipod/iphone/ipad video and audio integration.
I'm planning on getting the Navtool for the RDX to be able to do the same thing again. Is the only reason you have the USA Spec for Audio? I think with the 2013 RDX and using the Navtool for it, sound is sent to the system.
But I want my ipod connection only there for web video and some stored video I keep on my ipod. Otherwise, I'd like to do what you did with that extra USB reader thing because (as mentioned in the thread), it's real annoying to get videos on an ios device.
Also I wonder if with the navtools I can listen to music off my ipod without having to go through the Acura head unit controls because it'll be too annoying to find songs. I like having the ipod in my hand and manually finding things to play.
The NavTool is only for video and the USASpec is only for Audio. Keep in mind that if you are using an iDevice for both audio and video, you will need a cable other than the car's to separate the signals.
If you are only looking to play music off of your iPod by hand, just use a 3.5mm male to male (no homo) connector to the AUX input of your car.
Shahryar (12-10-2012)
I know about the Aux input but I was always under the impression that sending sound to the system via an iDevice connection cable would be the best thing.
One other complication is that I have an iphone 5 but also an 4g ipod touch. One uses the lighting connector, the other doesn't which means I would need to get an adapter. Ideally I could have multiple connection options. Maybe if I get a non-iDevice tablet (surface, nexust, etc) which is friendlier with playing various movie formats, I could easily connect that in. I have to explore the NavTool more or find a good place to ask questions. I don't want to hijack the groupbuy thread
At the end of the RDX NavTool install video, it mentions sound will play through the system: https://www.youtube.com/watch?v=mE0Y...layer_embedded .
Originally Posted by NavTool.com
NavTool is a video only input interface module, which means an FM modulator, FM transmitter or an auxiliary audio input interface adapter needs to be used to connect the audio signal from your external AV source to your audio system, if your vehicle does not have an auxiliary input already available.
They make adapters for compatibility issues: http://www.cellphoneshop.net/30micro...FegWMgodqRkAOQ
Don't worry about hijacking this thread. I think we are still on topic.
I asked some more questions to navtools in the group buy thread from post #31 to post #40 . Looks like the navtools unit for the RDX does indeed support audio BUT only for devices up to all the new ones with the lightning connector from the iphone 5 onwards. So that's good news for watching vids/listening to music off iphone 4s but bad news for watching videos off the iphone 5.
The video out for the lightening plug is a debatable topic on the interwebs.
Right now its not supported by Apple, BUT they claim there will be an HDMI and VGA converter coming which means a new IOs that will produce video out.
That being said, NavTool will have some upgrading to do but you wont see it anytime soon.
As for the 30 pin plug, my USAspec/NavTool combo still works flawlessly as long as the app produces and video out option you wont have any issues. Note that flixster does not.
I wasnt aware that the NavTool carried audio (admittingly I didn't care to keep up) , but this may be a new enhancement which is great for you guys.
^ I think I'll just pull the trigger on it because I don't know what else I can get for video to my Nav. I had an '08 IS 350 from 2009 to last month when I traded it for the RDX, and in it I had VAIS TECH's SL2Vi which brought audio and video off the iDevices. But I didn't know their plans for Lightning connector iDevices going forward
I would.
I'm not sure how that other device works, but keep in mind the issue isn't the device manufacturer. Its the phone manufacturer.
Once the phone is capable then the others will catch up.
Can you post the evidence of the NavTool integrating audio? I am only so skeptical because the site itself says it won't.
HEAVY_RL (12-19-2012)
That's what I thought too because the navtool site says video only for this product. But the install video mentions audio should also come. And when I confirmed in that groupbuy thread, the navtool poster said audio does come through
Oakes
Wash & Wax
10-12-2015 11:17 AM
C2CuSn07 TL
09-11-2015 06:54 PM
