Using Blue tooth to check messages
Old Mar 14, 2006 | 08:55 PM
medrxman's Avatar
If you call you home and get theanswering machine, is there a way to verbally enter numbers(e.g. access code)?
Old Mar 14, 2006 | 11:13 PM
kgd's Avatar
kgd
You can press the send button and say the numbers then enter. It doesn't work really fast so you may be better off entering them on the keypad of your phone once the answering machine picks up.
Old Mar 17, 2006 | 07:37 PM
Nocturnal's Avatar
You could program the access code in an HFL entry. You know, *86PP1234 . Use one or more pauses depending on how long it typically takes for the connection to be established.
Not very secure but once some dude has your keyfob you've got trouble anyway.
Old Oct 7, 2007 | 11:28 PM
medrxman's Avatar
You were close..say the numbers then say "SEND"..that works
Old Oct 11, 2007 | 11:29 PM
Don Melcher's Avatar
Tried that - didn't work. Never sent the access code.
Old Oct 12, 2007 | 09:57 AM
dwboston's Avatar
Store the voicemail number and access code as separate HFL entries. Voice dial your voicemail, when the call connects, say "Send Code" or whatever you call the access code. It works for me with my work voicemail.
Old Oct 12, 2007 | 10:15 AM
GoHawks's Avatar
2012 Cadillac CTS-V Coupe
Ditto for me. Our voice mail here is pretty complicated. You have to hit # when it answers, the you must get transferred to another system because it rings, and then picks up and you have to put in your extension and passpassword.
I just created the following.
I called it "Voicemail login"
E = Extension
P = Password
_ = Pause (in my case 5 pauses)
so I entered "#_____EEEEE#PPPPPP#"
So when I want to check voice mail, I'll say "Call voice mail work", when it answers, I say "Send Voicemail login"
Then I'm in.
Yikes
May 3, 2021 04:29 PM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
merc009
Jan 27, 2016 10:34 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
sockr1
Oct 1, 2015 01:31 AM
