USA SPEC SAMSUNG Galaxy S3
Old Oct 14, 2012 | 07:07 AM
253RL's Avatar
Are these compatable? I upraded from the iphone 4 to the s3 and didnt make sure the usa spec is compatable TIA!
Old Oct 14, 2012 | 09:00 AM
HEAVY_RL's Avatar
well they do make a iPhone plug to micro USB conversion plug so it might work.
Old Oct 14, 2012 | 12:31 PM
coopcoop30's Avatar
^^Would it work with the software though? Maybe you could just go through the headphone jack. I'll tell you what I did. I went on ebay and purchased a used 120GB Ipod classic and keep it in my trunk. I bought it for $100. Best investment so far for my car.
Old Oct 14, 2012 | 03:00 PM
253RL's Avatar
Well if it doesn't work I'm screwed because I only use pandora, however in thinking if I can get some sort of adapter from the s3 to USB plug on the USA spec box pandora might work, but then again that software thing
Old Oct 14, 2012 | 03:37 PM
Matt W's Avatar
$3 option:
$30 option:
http://www.cablejive.com/products/dockBossplus.html
Old Oct 14, 2012 | 06:13 PM
coopcoop30's Avatar
That $3 option is what I was thinking.
Old Oct 14, 2012 | 06:46 PM
253RL's Avatar
Sweet looks like one of those should work. Ill keep y'all updated
Old Oct 14, 2012 | 07:42 PM
HEAVY_RL's Avatar
as long as it transfers pin to pin the signal is the same
Old Oct 16, 2012 | 03:21 AM
253RL's Avatar
Just bought that 3 dollar option, got two so i can plug my phone into my tv. Also I didnt notice any usb type connections on the usa spec so one can only hope the av connectors work, im led to believe they will because why would usa spec put the, there? hopefully!
Old Oct 16, 2012 | 09:02 AM
HEAVY_RL's Avatar
I did a little reading and it seams as if you need the audio jack for this to work.
The micro USB connector is mostly for charging.
Old Oct 16, 2012 | 02:46 PM
oo7spy's Avatar
Is this only a solution because your car does not have the 3.5 mm jack?
Old Oct 16, 2012 | 06:46 PM
HEAVY_RL's Avatar
The jack is the output for microusb charging phones.
The question is how to get a GS3 to work on USA spec, so he would need a conversion from the 30 pin iphone to a headphone jack to get sound.
The dual cable above is to charge and play.
Old Oct 21, 2012 | 01:09 PM
253RL's Avatar
Ok so it works. The 3 dollar rca cable hooked up to the inputs on the usa spec module and the 3.5mm end plugged into the headphone jack on the S3 phone. Im sure this would work with almost any phone with headphone jack or ipod maybe. however you loose all function for using nav screen to select songs etc its all done on the phone. Also no charging supported. However It does not bother me Im just glad i can listen to music period. My 2010 Crv comes factory with USB port and when i plug my usb from S3 to it, It says unsupported and will not work, it worked fine with my Iphone 4 so ill have to dig into that later. but for $130 for the usa spec unit im still happy because there arent many cheaper options out there period unless the stock nav has rca inputs on the back of it.
Old Jul 7, 2014 | 04:01 AM
253RL's Avatar
Can't believe I forgot about this. I'm looking for solution cuz I have no pandora. I forgot I was able to make usa spec work with the rca method.
08KBP_VA
Oct 22, 2019 01:55 PM
emailnatec
29
Sep 28, 2018 04:27 PM
jsonkimz
Mar 28, 2016 07:49 PM
lbabus
Oct 12, 2015 07:00 AM
Tribalheads
Sep 29, 2015 03:24 PM
