USA-Spec malfunction?
Whats the likelyhood these things stop working? Is it a common issue? Im almost sure it stopped workinng but not sure for certain. Ive had it for just over 6 months... theres no warranty on these? I really hope i dont have to buy a new one, pretty frustrating if so and considering this one may have kicked the bucket after under a year, I'm not sure I will, any help or input is greatly appreciated. Im running the Bt45-hon with xmTuner fyi....
Thanks in advance 😩 P.S. maybe its my phone? |
You probably have already done this, but I would check the BT45 FAQ page at: BT45 FAQ and Troubleshooting
When you say stopped working, what do you mean? Is it the BT45? Where did you buy it from?
Originally Posted by projektvertx
(Post 16053664)
I had mine in the inner trunk lining for 4 years under hot and cold extremes until I relocated it to inside the car, and I never had any issues :dunno: Then again, electronics are picky so it's entirely possible.
Originally Posted by Ratheruneeq
(Post 16053457)
^^^^ According to my understanding the only thing different between the two unit is that BT45-Acu let you keep the live traffic in your navi and BT45-Hon won't let you keep that feature.
(Post 16054631)
Check that your connection is good. I ordered first unit which I happened to have a different issue with so I replaced it, but at the first install I connected all successfully, and for life I could not make it work. I went ahead and carefully unplugged all and re-plugged everything in making sure all connections were firmly IN.
Perhaps there is a disconnect due to loose connection? |
Originally Posted by deepa1600
(Post 16054641)
I am not an avid xm user and i don't have xm option in my car so theoretically bt4t-hon should work i think. And i prefer google for traffic updates.
