Rewire Fog lights
Old Mar 14, 2010 | 11:47 AM
alex1372's Avatar
Rewire Fog lights
Hey you guys,
Does anyone has any diagrams or something on how to rewire fog lights switch so I can turn on fogs with side markers only without turning low beams?
Old Mar 18, 2010 | 11:53 AM
MaxAlexand's Avatar
I'm planning to do this project soon.
From the wiring diagram in the service manual, it looks like you just need to hijack the white wire coming from the switch on the turn signal stalk, and run it directly to the fog lights (just bypass the logic circuit/black box). I'm hoping a short section of wire maybe 1', no more than 3', tapped in in the steering column to an undiscovered point under the dash. I'll likely place a diode inline to prevent sending juice backwards into the logic circuit (would not likely matter anyway).
The way the wiring diagram looks, you could then have fogs with Low/High/Park lights, and they'd still shut off with the car, or the switch.
Old Mar 18, 2010 | 12:13 PM
poppintec's Avatar
i don't have details i had someone run an independent switch for them, so it still works on the oem switch and new button installed
Old Mar 18, 2010 | 07:00 PM
alex1372's Avatar
Thanx Max! Can you post a pic of that diagram??
Old Mar 19, 2010 | 09:24 PM
MaxAlexand's Avatar
This is it. The only problem I see is figuring out where the "Combination Switch Control unit" is.
Hopefully it is not all contained in the stalk. That would require some micro-surgery.
Old Mar 19, 2010 | 11:49 PM
vletnguyen's Avatar
i really hope you make a DIY install tutorial.
i just ordered 2000k HID kit and this would be awesome!
Old Mar 20, 2010 | 07:48 PM
alex1372's Avatar
Thanks for the diagram, hopefully I could read it and compare it to real wires I'm planning to do it when it will be warmer outside - after two days of 65 degrees we have freaking snow on the ground again
Old Apr 3, 2010 | 10:45 PM
vletnguyen's Avatar
any updates?
Old Apr 13, 2010 | 12:41 PM
MaxAlexand's Avatar
Sorry, no updates yet.
I got rear-ended in traffic and my car is still in the shop.
Old Apr 15, 2010 | 08:27 PM
alex1372's Avatar
Same for me no updates yet - don't have time on weekends. But I actually decided to make two separate switches: one for fogs, and one for front led's, kind of like Slawek's I'd like to hit all of it in one time... Did I mentioned that I tried to change HID and it took me almost two hours to get the bulb in on drivers side; and about 5 minutes on other side
@Max - sorry to hear that you got rear-ended
Old May 9, 2010 | 09:14 AM
MaxAlexand's Avatar
Update - I've got the steering column taken apart, and I've located the wires in question.
I piggybacked a wire onto the signal output wire from the fog light switch, then I cut the output wire coming from the combination switch control unit (located inside the wiper switch), and ran my piggybacked wire to the output.
My though was, I'm simply preventing the combination switch control unit from being able to decide when the fogs should be allowed to come on.
Except. . .
When I reassembled the connectors, I had NO exterior lights. So, I left it sit, and got a good nights sleep. I'm going to try again this morning. I'll likely put it back stock and make sure I haven't damaged anything, then do some wire testing to determine the circuit, instead of trusting the wiring diagram.
Wish me luck.
Old May 9, 2010 | 04:05 PM
MaxAlexand's Avatar
No luck.
I've put everything back that I modified, and still doesn't work. I've apparently angered a computer somewhere.
The headlights work in automatic mode - Always - even with the switch in the "Off" position. With the car and all switches and accessories off, the headlight switch has no effect whatsoever. Hazard flashers work normally.
With the car running, and headlights on, moving the switch has no effect, except if you place the switch in the "On" position, then:
-Attempting to activate high beams causes the highbeams to flash rapidly.
-Attempting to activate fog lights causes the fog lights to flash rapidly.
-Turn signals flash rapidly when activated.
Looks like I get to tuck my tail and head to the dealership. :-(
Old May 10, 2010 | 06:03 AM
christopher1's Avatar
this car is very...
computer control,not like the old days cars where mod friendly. i just change the oil and drive.... hope it works out for you.
Old May 10, 2010 | 07:33 AM
MaxAlexand's Avatar
I have a feeling I'm about to learn this lesson the h$rd way.
Old May 11, 2010 | 09:35 PM
MaxAlexand's Avatar
Dealer says, "Maybe this, maybe that, leave it with us, and maybe we'll find the problem".
So I gamble on the $147 Wiper Switch/Control module.
No luck.
I'm on to try to find the Electrical Troubleshooting manual.
Old May 11, 2010 | 09:41 PM
MaxAlexand's Avatar
Does anyone have a copy of the Electrical Troubleshooting Manual for a 2007-2008 RL?
Old May 12, 2010 | 12:08 AM
MaxAlexand's Avatar
Car is now fine, my ego is hurting.
Maybe I can now serve as an example of how NOT to troubleshoot.
I assumed the problem was NOT in the stalk mounted light switch because although things were acting incorrectly, the switch did activate the correct items.
My error was, the switch had a defective solder trace on the ground wire. Which meant that, under the right circumstances, it could trigger the correct items, but due to lack of a ground wire, they wouldn't work correctly.
Had I simply followed the continuity test for the main light switch, I would have known immediately what the problem was.
Stay tuned. I've corrected an error in the manual, and try again. . . Once i've healed.
Thanks for listening.
Old May 12, 2010 | 12:30 AM
vletnguyen's Avatar
At least you're attempting this. I give you props!
I was just going to be lazy and rewire to different switch to battery with fuse.
however, i'm going to see what you come up with and hopefully adapt it.
Again, thanks for attempting this as it will help many members.
Old May 12, 2010 | 07:18 PM
CFoote's Avatar
Ouch. So you needed a new turn signal stalk? Hopefully under warranty?
Old May 14, 2010 | 01:43 PM
MaxAlexand's Avatar
I was able to repair the circuit board inside the stalk by laying a single strand of copper wire on top of the circuit and soldering it in.
I likely could have removed my jumper wire and taken it to the dealer for a free repair, but I figure I gambled on this mod, no fair tricking someone else into paying for it.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
