Rear View Camera Works on 2005!
Old 05-27-2016, 12:10 AM
GaRaS's Avatar
All,
To those that want to put a rear view camera oem on their acura rl 2005. It work all u have to do is swap the navigation dvd with a 2006 navigation dvd. Radio & XM still works after swapping. I just finish testing it right now.
Old 05-27-2016, 01:59 AM
GaRaS's Avatar
Below are the test pictures for the rear view camera. This is also the part #39540-SJA-A310-M1 that i used, i got lucky and purchased it only for $100. I ordered a rear view camera kit in hongkong and will post more picture when i will install the camera.
Old 05-28-2016, 11:50 PM
kcjohnnyboy's Avatar
is this the oem kit for rear view camera?
Old 05-29-2016, 12:09 AM
GaRaS's Avatar
The acura rl oem kit is discontinued and nowhere to be found. The oem kit 08B21-SNB-B00 is for honda civic si that i ordered from Hongkong and still transit coming over here, i ordered it so that it can hold the camera but i still have no clue on how i can mount. Hoping to receive it this coming week. I'm still happy that its working on 2005 model where other's failed and nobody bother to swap the navigation dvd. I've read somewhere swapping the 05 navi to 06 navi will kill the radio, i'm still laughing until now for whoever said that.
Old 06-02-2016, 08:53 AM
duke3k's Avatar
wow..good work...nice experiment... i had to go the navitool route
Old 03-06-2017, 01:57 PM
GaRaS's Avatar
I have finalized installing the camera on my 2005 acura rl. I used a 2007/2008 oem RL camera in ebay with wiring + the green plug to the navigation and use a xlr wire.
projektvertx (03-06-2017)
Old 03-09-2017, 08:12 PM
Shoxrider's Avatar
Can you elaborate on this process? Software needed? Where did it plug into?
how much did it cost?
Old 03-09-2017, 08:36 PM
GaRaS's Avatar
The 06 navigation cost me $100 and the camera cost me $145 including the wiring and I added some xlr wire from navigation until to the trunk. I bought them at ebay.
teh CL (03-14-2017)
Old 04-12-2017, 03:49 AM
9th Gear
Jimmy510's Avatar
hey! So how did you wire up the camera? I picked up a oem camera but I don't have the complete attachment kit and can't seem to figure out how to wire it up without the attachment kit. Thanks!
Old 04-23-2017, 04:36 PM
9th Gear
Jimmy510's Avatar
Well I was actually wondering which wire did you tap into? Thank you
Old 04-23-2017, 04:47 PM
9th Gear
Jimmy510's Avatar
Adding a back up camera
i was wondering did anyone on here tried doing the DIY similar to the tsx diy but with a oem camera? I recently purchased a oem back up camera but it is missing the 6 pin connector.
So on page 10/12 I have #39 but I am missing the connector on #40 That would plug into the navi control unit, so i was wondering is there any other way to get it to work without this connector? Or which wire I can tap into?
http://acura.bernardiparts.com/Image...a_BII31129.pdf
Tsx diy
Backup Camera Install - Acura TSX Forum
Old 04-26-2017, 04:37 PM
GaRaS's Avatar
It all came with the wire when i purchased the camera, i just added with xlr wire.
Old 04-26-2017, 05:51 PM
9th Gear
Jimmy510's Avatar
Oh I was curious because I see in the picture that some wire was cut and tap
Old 04-26-2017, 05:59 PM
9th Gear
Jimmy510's Avatar
Anyone got any idea on what I can do?
Old 04-26-2017, 07:55 PM
GaRaS's Avatar
Yes some of the pictures cause i was testing to make sure that its working.
QUOTE=Jimmy510;16006659]Oh I was curious because I see in the picture that some wire was cut and tap[/QUOTE]
Old 04-26-2017, 08:07 PM
GaRaS's Avatar
Is this what ur looking for?
Old 04-26-2017, 08:20 PM
9th Gear
Jimmy510's Avatar
yes that is! Would you be able to tell me the pin or post a picture thank you
Old 10-12-2017, 05:54 PM
6th Gear
Skandha's Avatar
Hi, sorry for Necro-ing the thread.
About to buy a '05 RL in that nice Opulant Blue Metallic. Was looking into the camera and Aux/Bluetooth situation on here.
So to get this setup on a '05 RL, I'd need the following?
08B21-SNB-B00 OEM camera Kit
The 06 Navigation DVD drive itself, not just put the 06 disk in my 05 NAV DVD drive
That camera trunk wire harness
I'm looking on ebay right now, the DVD drives either say a range of "05 06 07 08" or the ones that specifically say 06 are $200-300+
This 05 already has NAV but I'd still need to swap out the DVD Drives?
Can't seem to find a wire harness that matches up with the ebay screenshot you posted.
And where would be a good place to order that OEM kit?
Sorry for all the questions, I'm pretty technically inclined but still getting into the car stuff,
Old 10-13-2017, 03:10 PM
6th Gear
Skandha's Avatar
Okay did a lot more research.
If I'm correct, need the following:
39540-SJA-A310-M1 DVD drive
08B21-SJA-B00 Mounting Kit
08A21-6H2-360 Camera
All the websites I've seen so far say that the mounting kit is discontinued in the States, seems the cameras are getting hard to come by as well.
DVD drive seems pretty straight forward, but man the ebay prices are high. Though I guess I could flip the 05 one to compensate.
Friend gave me the contact info to someone in japan who might be able to ship me one from there though.
projektvertx (10-14-2017)
Old 10-14-2017, 03:57 PM
GaRaS's Avatar
Yes u are correct at least u need an 06 dvd drive. Also about the camera i ended up using the 07/08 camera and ended up adding wires (xlr 3 pairs gray color on the pictures) to extend it . Dont bother purchasing the mounting kit since its not compatible from japan.
Old 10-15-2017, 10:24 AM
6th Gear
Skandha's Avatar
Hmm I see, what about the wiring harness? am I just splicing into the existing one on the "05 or would i still need the harness from another year?
So any suggestions if I can't get the mounting kit? I'd prefer the outside of the car looking as clean as i can get it, so need at least the camera housing for it.
Looking online, the cameras from other models of Acura around that time are easier to find, Am I wrong in thinking that these cameras would be usable as long as I have a Backup Cam capable DVD Drive and the wiring is still the same?
Old 10-16-2017, 11:05 PM
GaRaS's Avatar
Get a 07/08 camera, there is one in eBay cost $65. All u need to do is add wire (xlr cable) and splice to the camera and as well the green plug that goes to the navigation dvd. U need to cut and use Dremel to mount the camera to look Oem as that what I did . The mounting kit and the camera add ons are for 06 but u need to relocate the switch to open the trunk. Mounting kits for the camera is hard to find.
Old 11-19-2017, 03:08 PM
GaRaS's Avatar
Those who are looking for a used 06 camera with kit , there is one listed at ebay for $99 excluding shipping. https://m.ebay.com/itm/JDM-Acura-RL-...8AAOSwAaJZ~Y0J
Old 11-21-2017, 12:17 AM
hugous's Avatar
That was sold. By the way, mine is 06 so I guess I dont need DVD drive. Where can I get green plug to navigation? can you post more detail how to splice wire from camera?
I also consider NavTool to go with after market camera.
Old 08-30-2019, 12:01 PM
Moises Aguas's Avatar
I know is like 2 years late but...
I have followed the TSX DIY thread and it worked for me, no need to add a new DVD or anything; just what the guy stated on the DIY.
I have an Acura RL 2005 with Navi, no XM (I bought it in Mexico. I think the car comes from Canada)
You could use one of the molex connectors from the TSX Thread if the camera you bought doesn't have it, I'm pretty sure it will work
00TL-P3.2
02-11-2019 11:23 AM
OnlyDaanish
03-24-2018 09:17 PM
Comfy
05-20-2016 01:02 PM
MayorMcCheese
05-09-2016 06:36 PM
blaser
03-05-2016 04:42 PM
Quick Reply: Rear View Camera Works on 2005!
