Phonebook help.
Phonebook help.
Ok, I know I'm lazy and I apologize if this has been posted elsewhere. I did a cursory search here and a quick glance of the owner's manual: but I am still a little confused how to add numbers to the addressbook. Right now I have to manually "dial" the numbers using the voice commands. My phone synchs up no problem (Nokia 6600 with TMobile).
Is there a way I can do shortcut commands (like #2) that correspond to numbers in my phone's addressbook? Or do I have to add numbers to the RL's addressbook which are seperate and distinct from my phone?
Sorry for the noob questions.
-N
-N
No problem. Do this:
1. Push the bluetooth/HFL talk button
2. Say 'phonebook'
3. Push the talk button again and say 'add' (you may want to listen to the prompt to verify this)
4. Follow the directions, but if I am not mistaken it will then ask you for the number of the person, you would push the talk button, then speak the phone number you want to program. Then it will ask you to confirm, you say yes, then it will ask for the name for that phone number, piush the talk button, then say "joe" or whoever it is, it will confirm, then it will be added.
These are not EXACT steps, but if you pay attention to the prompts once you get into the phonebook system, you shouldn't have problems.
2. Say 'phonebook'
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
