Passenger HID Randomly Will Go OFF
Old Nov 13, 2013 | 09:48 PM
Austin Schmidt's Avatar
Hey everyone,
This is my first post to this website, and I am proud to say that I just purchased a 2005 Acura RL.
The only issue I have had so far is that yesterday, after having it for not even a week, the passenger HID headlight will randomly just shut off. It will not turn back on again until I turn off my headlights completely, and then turn them back on.
What could be the problem?
Thank you
Old Nov 13, 2013 | 09:53 PM
HEAVY_RL's Avatar
replace the bulb, if that doesnt work replace the ballast.
Also ensure you have a strong battery and a good alternator.
Old Nov 14, 2013 | 06:36 AM
db22's Avatar
BTW - if you can do the bulb change yourself you could save a few hundred in installation costs. The other consideration is changing both bulbs so that they are both the same color and if you do it by pulling the front bumper then both changes are easy.
There are threads on how to do this and our search gurus, Heavy and 007, could probably help if you indicate that you wish to attempt this.
Old Nov 14, 2013 | 07:23 AM
Correct me if I am wrong, but if the bulb were the issue, wouldn't it show signs that it is going bad, such as flickering? Rather than just shutting off COMPLETELY, and then turning back on once I flip the switch back and fourth?
Old Nov 14, 2013 | 08:20 AM
HEAVY_RL's Avatar
I wont correct you, because you might not be wrong.
Like I said, its more than likely one or the other. You have your choices, replace one or the other, or seek other advice.
Old Nov 14, 2013 | 08:29 AM
oo7spy's Avatar
We have had a few people document ballast failures. Have you tried a "search this forum" with keyword "ballast"? Another part in the chain to consider is the ignitor, but I'm with Heavy, ballast or bulb.
Old Nov 14, 2013 | 03:12 PM
I found these online. What do you guys think?:
http://www.hiddepo.com/p8/D2S/D2R-OE...duct_info.html
Old Nov 20, 2013 | 01:11 PM
JRock80's Avatar
What was the resolution? Did you replace the bulbs, ballast or both?
Old Nov 21, 2013 | 03:00 PM
RL RT Joe's Avatar
I had my passenger light go out last week. It turned pink for about a week before going out all together. I didn't have any flicker problem with it. After going pink on me for a week it would come on at startup then before I could walk to the front of the car it would go out and stay off. I replaced the bulb and all is well again
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
rhdune16
Sep 28, 2015 11:31 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
