need remote help programming, and Navi and radio codes!! 2005 RL
I am buying a 2005 RL used and the navi codes and the radio codes are missing,,, also all the dealer has is the blade key, and no remote. I saw some remotes on ebay some say driver #1 and Driver #2!? which one do i need. and can i progeam myself and if so how ?
also the manual is missing and the codes are not on a sticker or anywhere else on the car... can anyone help?
thanks i have to decide weather to buy tomm so i need help
once you have proof of ownership you can get the navi and radio codes from the dealer
BUT
I would demand that you have them get those codes before you buy it because you obviously will not know if there is a problem with the system until after you have bought the car. And seeing that the tech is a major part of the vehicle you should NOT buy the car based on 1/2 of the experience.
A switchblade key sounds like the wrong key for the 05 . The car comes with 2 $300 keyless remotes which has added features.
You can have either driver 1 or 2 key but you need to buy a new key blank (acura/honda part number 35111sja305) - you can buy that online from curryacuraparts for 36 or cheaper at acuraoempartsdotcom if you live on the westcoast then have the key cut and programmed at the dealer or a locksmith to link to the car.
you can program the remote yourself or have the dealer do it if you're having them program it for you anyway.
good luck
what are th instructions for doing it myself?
handsom-hustla
11-13-2015 05:04 PM
SUPRMN84
09-02-2015 11:50 PM
05, 2005, 35111sja305, acura, bluetooth, code, codes2005, find, navagtion, navigation, programming, radio, remote, reset, rl
