Need help on HFL to enter call service #
I just got a service to call Canada inexpensively. However, I must dial an access number (which I can program into my address book) then after connecting and getting a signal, I must dial the actual telephone number. This can be quite cumbersome as the voice recognition messes this up quick easily.
Is there anyway to do this more simply?
Also, is there anyway to initiate a call on my cellphone then transfer it over to the HFL?
I cant help you with the first part of your question, however to answer this one, do the following:
Initiate the call from your cellphone
Press the HFL button
After the "beep", say "Transfer"
The call will now transfer to the HFL system of the RL
Originally Posted by somno
Thanks,
That does help for another issue of getting calls from my phone's address book more easily dialed.
Still not sure what to do about the Canadian calls.
Since the voice recognition often makes mistakes, this tends to be a problem for entering numbers after a prompt. I was hoping there would be a simpler and less error prone way to do this.
