Nav screen dull?
Nav screen dull?
Is it just me, or has anyone else notice that in the morning the Nav Screen seems to be dull?? I have try to change the backlight, contrast etc to help fix the issue but it seems to still be dull. At night the screen seems to work fine......has anyone run into this before?
I thought so to but after i got to work (10 min drive) it looks the same. Im going to maybe charge the battery since its freezing in NY maybe that might help....
Mine gets brighter after about 5 minutes. Did you have the screen on the whole time? Are your head lights on?
Thanks fellas for your response. I let the car warm up for 5 mins and im off, with this weather 5 mins is not good enough. Also yes i do have headlights on is that an issue?
I don't think turning the headlights on in the daylight dims the screen. The screen dims to night mode when the sensor reads low light conditions.
Mine is dull when it's cold but brightens up as the car warms up...not the engine, but the actual temperature inside the car. The colder it is, the longer it takes but it does brighten up. MDX screen is the same way.
LL
LL
MrHeeltoe
20
02-23-2023 01:54 PM
navtool.com
31
11-16-2015 08:30 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
